Author Topic: Tried to change the oil....  (Read 2452 times)
jlockwoo
« on: May 09, 2007, 08:39:51 PM »
The other day, I tried to change the oil in my 1975 cb750f. everything was going fine until I added the new oil and it seem it won't leave the tank. I have kicked the bike over more than I wish to talk about, yet the oil is still filled to the top of the tank(put in 3 quarts). I read a how to on oil changes before i did it. Just said to drain the oil from tank, filter, and engine case. Replace the oil filter, and put case lug and tank plug back in. Last step was, Refill oil and kick bike over a couple of time to get oil into case. Did I do something wrong???? Any ideas would be a great help.
thanks Jake
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
Re: Tried to change the oil....
« Reply #1 on: May 09, 2007, 08:53:22 PM »
You did it the way I do it. I do know there is a check valve to prevent the oil tank from filling the crankcase.
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
Offline Raul CB750K1
« Reply #2 on: May 09, 2007, 11:48:37 PM »
I was doing a pre-ride check a couple of weeks ago and discovered the level was just barely above minimum. I know the bike doesn't consume oil, but as I use it sparingly and couldn't remember when was the last time I ckecked, I just assumed it was low, but as I know too that the check valve is not completely oil tight, I started the bike and left it running for a couple minutes. I thought it would be enough for the oil to circulate. By looking at the tank, the oil was circulating but the level didn't change, so I just filled it.
Needless to say, at the first coffee stop I rechecked the level, and it was well above the maximum, almost to the brink of the tank!!! Seems that it takes more than two minutes for the oil to fully circulate.
Raul
Offline puppytrax
« Reply #3 on: May 10, 2007, 03:43:37 AM »
Did you get a straw and a paper cup from the coffee shop and "adjust" the oil level??  ;D
That would have been worth a pic...   :D
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #4 on: May 10, 2007, 03:55:31 AM »
jlock did you try  kill switch off so it wont start and  spin engine over till the oil goes down  prob just got like an air bubble in there  hope this helps good luck seven fifty four ever Craig in Maine
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
Offline Steve F
« Reply #5 on: May 10, 2007, 04:39:38 AM »
I can't get the proper reading until I start the bike and let it run for 30 seconds or more.  Shut it off and then check the level again.
jlockwoo
« Reply #6 on: May 10, 2007, 06:25:14 AM »
No, I haven't tried to turn it over with the electric start. I have a wiring issue that I must fix first. I am just worried about cranking it over like crazy with no oil in the case. Does anybody no how much oil the tank can hold? I have put 3 quarts in and its filled to the brim.
Thanks again Jake
Offline SohcCBs
  • 76 CB836F 77 GL1000
« Reply #7 on: May 10, 2007, 06:51:23 AM »
Open this plug and kick it over....maybe on the center stand in 4th rotate the tire.  If oil is cycling thru, it WILL come out this hole.  Don't ask how I know that....it'll make a bit of a mess.
If you don't get any oil thru this hole, since you've only put in 3qts., you might be able to prime the engine here with just a cup (or drain a cup out of the tank first if needed), but that'd be a guess on my part, but it may be why that hole is there.  To rid the system of air and priming.
« Last Edit: May 10, 2007, 07:01:59 AM by SohcCBs »
« Reply #8 on: May 10, 2007, 07:02:40 AM »
No. The first coffe stop was about one hour from home, so I thought it nothing happened for the oil been way too much over the max level, nothing should happen for the rest of the day. I rode about 300 miles that day, and back home, I used a big syringe to remove the excess oil.
Raul
Offline Bodi
« Reply #9 on: May 10, 2007, 08:41:26 AM »
The tank connects to the pressure oil pump. That pump feeds the engine through the oil filter and oil galleries to the bearings and rocker area, then the oil just dribbles down to the sump. Once the sump fills enough to reach the scavenger pump inlet the scavenger pump sends it back to the tank.
It takes a fair bit of pumping to fill the oil filter and galleries and start oiling stuff so that the oil starts dribbling to the sump. After enough has gone through the engine to reach the scavenger and start coming back into the tank you can check the tank level and fill it to the full mark.
There's a check valve in the scavenger pump that keeps oil from going back into the sump... sometimes that leaks a bit or even sticks open, so it's best to check the oil level just after shutting the engine off after a few minutes running; sitting overnight enough oil might have gone back through the scavenger pump that the oil tank will overflow (nasty mess) with the motor running.
You will have to kick the engine over for a leg-wrecking amount of time to get the oil system fully functioning after changing the filter and draining the sump. Unless you suspect a bad oil pump for some reason just assume all is well, and remember to add the rest of the oil when you get the motor running.
Offline jaknight
  • ....Round Town Ride......
« Reply #10 on: May 10, 2007, 04:24:21 PM »
Hi jlockwoo,
     Whenever I change the oil on my 750 K4, I put in just short of 3 quarts.  Then, with the kill switch on, I use the kick starter for 15 to 20 cycles.  Then I start the engine, let it run for 2 minutes.  Stop the engine, then check the oil level.
     From there, top off with oil as needed.  This is a recommended procedure by a man who was once a professional Honda racer............
     Perhaps one should remember that this was recommended for the earlier K series 750s; I am not positive this is a valid procedure for the f series bikes; just a thought.........
     ~ ~ ~ jaknight ~ ~ ~
« Last Edit: May 10, 2007, 06:29:20 PM by jaknight »
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
jay
« Reply #11 on: May 20, 2007, 06:02:06 PM »
i have 1978CB750f changed oil last night. i  was only able to get a little over 2 litres in.  i had to put kill switch off crank engine for a while. then i started the bike it seemed like it was circulating. toped it off . 2 litres and its over full .never had chance to take bike for ride because of rain. but hope i did every thing right.
bobsmith
« Reply #12 on: June 03, 2007, 08:57:59 AM »
You cant really "overfill" the drysump system, The excess  will simply show as overfill or if too much, overflow the tank (bad for right hand cornering) the scavenge pump will keep the sump from windage no matter how much oil is in the tank,  low oil is another story..
