Author Topic: Max Power with stock frame? (CB750K)  (Read 1702 times)
nickbee
« on: June 30, 2005, 11:35:48 AM »
I'm working on a rebuild of a '74 CB750K engine.  I know there are lots of ways to squeeze more power (bore kits, head work, cams) of of this engine.  I guess I'm curious to how much power a stock frame can safely handle.  What mods would be good for a frame with a higher power engine?
Thanks!
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: Max Power with stock frame? (CB750K)
« Reply #1 on: June 30, 2005, 11:50:37 AM »
I don't think you'll have a problem with the pig-iron frame.  You should give attention to the suspension and braking however.  Oh, and buy a good helmet  ;D
Dirk Laguna
« Reply #2 on: June 30, 2005, 12:55:11 PM »
....amen!
eldar
« Reply #3 on: June 30, 2005, 01:03:10 PM »
If you have a properly working suspension, the frame should hold up just fine. Now if you were to start bombing around with 100 bhp, then you could run into issues. Maybe.
