Author Topic: How to stop front brake squeal.  (Read 32769 times)
Offline toycollector10
Re: How to stop front brake squeal.
« Reply #25 on: March 09, 2009, 09:50:30 PM »
The caliper adjusting spring is on the bike for a reason. I cured my brake squeal by:
A. Removing the old rusty spring, it had lost its correct springy tension and was stiff.
B. Ordering the correct part (45119-300-020) off www.cmsnl.com
C. Fitting the new spring and adjusting it correctly as per the shop manual.
If you have tried everything else it would probably be worthwhile. It's a very cheap and easy fix, well, it was for me anyway.
Good luck.
1969  CB 750 K0
1973  CB175
1973  Z1 Kawasaki
haloskycrash
« Reply #26 on: March 19, 2009, 11:33:28 AM »
http://www.bikebandit.com
this site is cool cause it will remember your bike you have.  they have schematics of different areas of the bike (like front brake).  they are a little pricey. get the part number and visit http://www.cmsnl.com/
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #27 on: March 23, 2009, 06:28:53 PM »
Whoops!!  (hit the wrong damned button)
« Last Edit: March 23, 2009, 06:37:30 PM by coyotecowboy »
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
Offline WrightStuff
    • 1974 CB550 K0
« Reply #28 on: April 07, 2009, 01:52:08 PM »
where do i get braided, or stainless steel brake lines. i want to try this before i go to adding another disk and caliper to the front. i've also read here that a master cylinder from a GL1000 is bigger and could improve the hydralic force behind the hand lever.
In case you haven't found them yet...http://forums.sohc4.net/index.php?topic=44823.msg520010#msg520010
WrightStuff!
1974 CB550 K0
