Author Topic: Chain Maintenence?  (Read 1035 times)
Offline Loudpipe
  • Broken Vehicle Collector
Chain Maintenence?
« on: August 12, 2007, 12:13:59 PM »
Hey, just put a new chain on my bike and was wondering at what intervals I should oil/grease the chain, what kind of chain oil/grease is good, and what intervals I should expect to tighten the chain at?  I've got about 400 miles on it now, and have not had to adjust it even for the initial stretch I expected.  It's a DID O-ring if it makes any difference.
- LP
1974 Honda CB350F
Previous: 1978 Honda CB750F, 1971 Honda CB500K, 2009 Yamaha YZF-R1
Re: Chain Maintenence?
« Reply #1 on: August 12, 2007, 12:57:30 PM »
Unless you really flog your bike those o-ring chains don't need adjusting often, but check it often and adjust it when it needs it. When I fiqure it needs it I always lube my chain when I return from a ride and the chain is warm and I like chain wax, it is cleaner than other lubes and used every two or three hundred miles does the job. A little lube more often is probably better than half a can once a summer! Two of my bikes o-ring chains have around ten thousand miles and hardly any slack on the back sprocket.
Offline Loudpipe
« Reply #2 on: August 12, 2007, 03:40:36 PM »
Chain Wax? Is that a brand or just a type of chain lube?
- LP
1974 Honda CB350F
Ibsen
« Reply #3 on: August 12, 2007, 04:01:59 PM »
Chain Wax is a term. There are many different brands around.
This is an excellent chain wax:
http://www.maximausa.com/products/chainlubes/chainwax.asp
And here's another one:
http://www.cyclegear.com/spgm.cfm?L1=52&L2=&L3=&L4=&item=VAN_57-8130&tier2=266
