Author Topic: CX500C problems  (Read 7508 times)
Offline crazypj
  • I'm brill, me
Re: CX500C problems
« Reply #25 on: September 04, 2007, 07:50:35 AM »
You sure carbs are clean? CX uses 3 jet carb with a rubber plug over secondary? main.( I think secondary, don't have manual handy o reference) Its pretty common for left carb to be either flooding or partially blocked.
PJ
Offline turtle
  • 1980 CX500 Custom
Re: CX500C problems
« Reply #26 on: September 04, 2007, 11:30:25 PM »
"Finally, the CDI boxes on 1978-1981 CX500's are not ageing gracefully. These boxes are full of big capacitors, and the dielectric fluid in capacitors dries up over time, and can outright fail. Thus, operating CDI boxes are becoming a rarity these days. Usually they fail on one cylinder - intermittently to start, and then completely. CDI boxes are also very easy to kill by high resistances in 30-year-old spark plug wire resistor caps."
From Wikipedia
Two of ours failed. They seem to have a half-life of around 27 years. We are blessed with a friend who is gret with electronics. He completely dismantled one (carefully digging out all the resin) then replaced all the capacitors, diodes or whatever the electronic thingies are called, on the orignal circuit board. The bike runs beautifully, like it never has before. The other bike has had its CDI replaced with a second hand one but will probably need the treatment soon.
1972 CB350 Four
1977 CB750 K7
1979 Suzuki GT250 X7
1980 CX500 Custom
1980 CX500 Shadow
1981 CB900 Bol D'or
1982 CB750 F2
"If it ain't broke, don't fix it."
Offline droopy
Re: CX500C problems
« Reply #27 on: September 10, 2007, 03:43:30 AM »
http://choppercharles.com/cs/
this site will get you up and running thay can and will help you locate any parts that you may need also.
good group very dedacated to the cx500/cx650 and gl500/gl650 and the  ;D ;D ;D factory turbo version ;D ;D ;D fast bike fun to ride
2007 lifan 200cc sport ohc thumper
