Author Topic: charging problem  (Read 970 times)
summitlt
charging problem
« on: September 02, 2007, 08:26:33 PM »
76 750
Took the bike for its first ride today, running really badly. Choppy, spitting, wont go WOT. Then it eventually died.
Once it died, started wouldn't work, and the lights were really dim. Battery is close to flat dead, so its obviously not charging.
This a common problem? What routes shoudl i take to fix it?
Offline Gordon
  • 750K1, 550K2
Re: charging problem
« Reply #1 on: September 02, 2007, 08:57:33 PM »
The first step is to make sure you have a fully charged battery in good condition.  If the battery won't hold a charge under load, no amount of current from the stator will keep it alive.
summitlt
« Reply #2 on: September 02, 2007, 09:36:02 PM »
it was charged enough to spin the starter to start the bike, so it couldnt have been that low.
« Reply #3 on: September 02, 2007, 10:21:23 PM »
If there could be a question that the battery hasn't been maintained properly it could fry in 1 season. How old is the battery? Has the electrolyte level been maintained properly? Has it been kept in a warm environment over the last winter? Has it had a proper trickle/float charger hooked up over winter and while not in use? Are the lead cells sulphated?
Gordon is on the money! Don't even attempt to diagnose a charging issue without a known good battery. New battery is about $35. You may have used all the remaining reserve in the battery when you started it. The summer heat is brutal on a marginal battery. Try a new, properly pre-charged according to instructions, battery and go from there. If it goes down too my next step would be to do what all 30+ year old SOHC4 bikes need to have done, and I know you don't really want to hear this or yet do it, but............... DISCONNECT EVERY electrical connection on the bike, clean them thoroughly, tighten them, and reassemble using dielectric grease to protect them from future corrosion. If each connection had a very small resistance caused by looseness &/or corrosion then there is no way the battery would stay up. If that doesn't do the trick then it's time to start a real diagnostic program. Most of the hardware on these bikes holds up very well and doesn't often fail.
One other thought. You haven't recently switched to high performance coils like green 3 ohm Dyna brand? Those bad boys are really great but they'll really suck the juice.
Good luck!
Electrical problems will probably be your biggest pain in the ass with these bikes if you hang onto it. Just do it right and be done with it.
summitlt
« Reply #4 on: September 03, 2007, 11:21:18 AM »
Charged the battery fully and it runs like a champ now. Who wouldve guessed ?
« Reply #5 on: September 03, 2007, 12:31:25 PM »
Well... Gordon, if the printed records mean anything.
 ;D
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: September 03, 2007, 04:59:23 PM »
 ;D
I'll try not to let it go to my head. ;) :D
One thing to keep in mind if the same thing happens again in the near future is that it may still just be a battery problem and not a charging issue.  If you have a multimiter, with the battery fully charged, check the battery voltage with the bike running to see if it goes up with increased engine rpm.
