Author Topic: Well, doc, what seems to be the diagnosis?  (Read 3706 times)
Offline Hope
  • How did I become an
  • SOHC member since '01
« on: September 08, 2007, 12:39:12 PM »
I went riding today, even though upon my initial inspection of Cassandra, I saw this:
hmmm....  what is that stuff near my spark plug?  I've never notice oil or gas around my spark plug before.
I went riding anyway, and came back home... let the bike cool down, pulled the spark plug:
Where to start? What do I need to do?
« Last Edit: September 08, 2007, 12:43:11 PM by Hope »
Offline Gordon
  • 750K1, 550K2
Re: Well, doc, what seems to be the diagnosis?
« Reply #1 on: September 08, 2007, 01:01:46 PM »
Give the engine a good cleaning and ride as usual.  This will help you to see exactly where it's coming from.  From that picture, though, my first choice would be the rocker shaft seals.  If you pull the rocker shaft end covers (the part in the picture with the large phillips screw) you'll see what I'm talking about.  Each cover has two metal plugs with o-rings on them that seal the holes at the ends of the rocker shafts, and if the o-rings aren't doing their jobs properly, oil can leak past them and out through the bottom of the cover.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: September 08, 2007, 04:54:09 PM »
When Cassie's engine is clean and dry, you could also spray some foot powder on the area of interest.  When you run her next, the white powder will turn black right at the source of the leak.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #3 on: September 09, 2007, 07:19:53 AM »
Has it been apart recently? If so the soft washer under the bracket that holds the end cap may not be there, or damaged
RSV12K
« Reply #4 on: September 09, 2007, 09:14:27 AM »
My diagnosis is that you gave your bike a dopey name.
knack
« Reply #5 on: September 09, 2007, 09:56:07 AM »
Ouch!
« Reply #6 on: September 09, 2007, 10:31:12 AM »
Perhaps you'd like to explain why you thought it necessary to post derogatory remarks?
Offline medic09
« Reply #7 on: September 09, 2007, 12:50:57 PM »
+1 with TT.
I, for one, have to say a) it doesn't matter and ignore him (RSV is an illness after all), and b) it is kind of a classy (or is that cassie) name.   ;)
Me, I don't have names for bikes; excepting when things break, then it'll be things I can't say or write in public forums.  :D
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: September 09, 2007, 01:02:04 PM »
Hey Hope!  Any luck finding the source?
And Cassandra's a perfectly fine name for a bike (not that it matters what other people think, anyway) ::) :)
Offline 333
  • Time for change
« Reply #9 on: September 09, 2007, 02:35:30 PM »
He probably never felt the soul of his bike.  Talok about dopey.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline edbikerii
    • Gallery
« Reply #10 on: September 09, 2007, 03:42:55 PM »
I felt the soul of my bike a few times.  In fact, my bike's name came to me in a ragedream late one night in the garage.  My bike's name is "F'in piece of Sh1t"!
I think Cassandra is infinitely more classy, however.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline Hope
« Reply #11 on: September 11, 2007, 11:43:44 AM »
The source of the yuck has yet to be determined.  I cleaned the motor off, and went for a ride.  The yuck hasn't reared its ugly head again (not yet anyway).
I will probably either ride it to work during the week or I will definitely ride this coming weekend and try to see where it is coming from.
Offline Gordon
  • 750K1, 550K2
« Reply #12 on: September 11, 2007, 04:14:56 PM »
You can find out really quick by just pulling off that little cover.  If there's oil inside it, then there's your leak.  It's literally a 30 second job.
Offline dusterdude
« Reply #13 on: September 12, 2007, 10:51:23 AM »
yea,stone him.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline peten
  • wait...what?
  • if at first you don't succeed, get a bigger hammer
« Reply #14 on: September 12, 2007, 12:11:57 PM »
not related to the leak, but the gasket on the spark plug in your pic was not crushed.  plugs should be tightened to about 14-18 ft-lbs, enough to semi-squash the gasket.  just thought u should know.
1978 cb550 sortacafe
1980 kz1300touring(not anymore)
1980 kz1300 standard
1975 yam xs650 w/star mags
Offline Hope
« Reply #15 on: September 15, 2007, 08:28:57 AM »
okay... finally Saturday... Cassandra and I had some alone time...  Here's what I found when I took the screw off the cover:
Time for me to get some of those rubber rings?
« Last Edit: September 15, 2007, 09:33:25 AM by Hope »
Offline mark
« Reply #16 on: September 15, 2007, 09:00:13 AM »
Yes ma'am. And maybe a couple of the soft aluminum washers that go under the tabs that the covers screw on to.
She might also be pleased if you polished up the covers a bit while they are off.
Happy trails.
F you mark...... F you.
Offline Hope
« Reply #17 on: September 15, 2007, 09:23:35 AM »
Yeah, I planned to polish the covers... off to the Honda dealership.  Hopefully this fixes my yuck problem
Offline Hope
« Reply #18 on: September 16, 2007, 08:41:05 AM »
Once again, thanks to all the folks who helped.  Honda had 2 of the O-rings I needed.  I ordered the other 2.  (I plan to do both sides.)  I put the screws in wood bleach because they didn't have the screws either.  Those are on order to.  Polished both of the covers up.  They now match all my other polished aluminum.  Gotta love a happy ending:
« Reply #19 on: September 16, 2007, 10:05:43 AM »
Hope,
Friendly advice offered:
Those rocker shaft plugs/cover reveal the rocker shafts themselves.  If you peer straight into the shaft holes you can see the shaft ends themselves.  They should appear perfectly centered in the holes.  If they do, count yourself lucky.  Pre 77 CB550 cam covers did not have a feature to hold the shafts from turning with the the rocker movement.  This wore the cam cover aluminum and altered the rocker geometry, which can lead to abnormal cam & rocker wear.
If your rocker shafts are still centered in the bores, you have little to be concerned about.  However, a preventive measure to keep the shafts from turning, is to add an extra oring into each bore before installing the end cap plugs.  This adds extra pressure/ turning resistance, to keep the shafts in place and not turn with the rocker movement.  This tip courtesy of Mike Nixon.
