Author Topic: CB750, Went to change oil for first time and found this  (Read 9143 times)
Offline motomotard
    • GoGo Garage
« on: September 19, 2007, 02:36:15 PM »
73' CB750
So i got this bike this summer and went to change the oil for the first time today. I took the pipes off for better access and looked under the bike. The oil drain plug is the larger one on the lower corner of the pan right? Maybe im just stupid, but im pretty sure what im looking at is the drain plug.
If not please let me know, if so then why do i have this rubber cement like compound on my drain bolt. I tried to scrap it off and it wouldnt budge. I guess someone tried to stop a leak. Let me know if this is normal and what i should do about it.
Thanks for the help, here are pics.
Offline roadkill savior
    • Hondachopper
Re: CB750, Went to change oil for first time and found this
« Reply #1 on: September 19, 2007, 02:45:15 PM »
someone had a leak and "fixed" it with JB weld.
Get another pan and a new bolt with a new crush washer and an oil pan gasket.
Mine was leaking and I just replaced everything, lucky enough I had a spare.
Offline motomotard
    • GoGo Garage
« Reply #2 on: September 19, 2007, 02:54:42 PM »
you think i should replace the whole pan? id like to get that #$%* off, but i dont think its going anywhere.
Offline Kevin D
  • SE Michigan
« Reply #3 on: September 19, 2007, 02:57:09 PM »
I once cracked my oil pan by overtorquing the drain plug, I had it welded but it still leaked. A new pan was my remedy. You might find a used one if you look around.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #4 on: September 19, 2007, 03:06:24 PM »
My guess is that the threads are stripped, and the cheapo owner glued it on before selling the bike.  Welcome to PO bike mod "improvements".
You will probably need heat to remove the JB weld, like a soldering iron tip.  Then deal with the mess afterward.  I suspect a replacement pan would be the easiest remedy.
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: September 19, 2007, 03:09:16 PM »
Yep, definitely time for a replacement oil pan.  Even if you could get the JB weld off without damaging the pan yourself, there's a good chance it's already been damaged or cracked by the PO which caused him to go for that quick fix in the first place.  Good, used pans can be found pretty cheap on ebay or in a local scrap yard.  Get a new gasket for it, too.
edit: looks like TT said basically the same thing :)
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #6 on: September 19, 2007, 03:37:31 PM »
*ouch* yeah, that work is definitely a candidate for the "APO (a**hole previous owner) Thread - Your Worst Stories . . ."  post here:
http://www.sohc4.us/forums/index.php?topic=24582.0   ;D
Maybe add your pictures to that post, read others encounters with their APOs and realize you are fairly lucky, compared to some others 'joyous' discoveries of previous owners' work done to their bikes . .  . .lol
« Last Edit: September 19, 2007, 03:40:35 PM by MoTo-BunnY »
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
arbormystic
« Reply #7 on: September 19, 2007, 03:40:09 PM »
Well if you have access to nitric acid or high concentration hydrogen peroxide (30% is what we have in my lab at work) you can desolve the JB weld but both are kind of dangerous to work with.  I only know this because we use JB weld every now and then at work and those are the  two chemicals that are most destructive to jb weld.  I would agree with everyone else and replace the pan.
« Reply #8 on: September 19, 2007, 03:56:30 PM »
You may be able to chip away the JB if he left it oily when he slipped the junk on it. You can probably burn it off with a torch (gently). All of this is probably better done with the pan off. Maybe once it is off you can get someone to helicoil it.
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #9 on: September 19, 2007, 03:59:06 PM »
you could just drop the whole pan, clean out the gunk and check the screen while you're there.  really should be done anyhow, just to see what surprises the PO has left you.  or you could buy a used oil pan from me  ;D
i have some misc parts for sale from a used engine in the "parts for sale" section.  according to bikebandit.com, the oil pan for a '73 is the same as my '78.  pardon the shameless self-promotion, gotta pay for my frame kit somehow!
bobp
searching for a dr350se
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #10 on: September 19, 2007, 04:15:45 PM »
You have two basic choices.
1.  The Replace route: oil pan (ebay-$15), oil pan gasket (OEM-$10), drain nut and drain nut washer (OEM-$9). plus shipping ($20- $30).  Total $54-$64, plus the fun of parts hunting and ebay.
2.  The Repair route: oil pan gasket (OEM-$10), peroxide (chem supply-$4), drill & tap, metric nut and washer (hardware-$2) plus shipping ($10)  Total $26, plus the enjoyment of saving $28, drilling, tapping, chemistry and the satisfaction of salvaging old parts.
Hmmm. Tough choice. (no sarcasm intended) :-\
« Reply #11 on: September 19, 2007, 04:30:26 PM »
Here's another option.  Leave the drain plug alone and JB welded.  Drop the whole pan for each oil change.  Wear long chemical gloves.
Burn/delete the pictures you took.
When you are tired of the bike, sell the problem to the next owner. Maybe the guy that did it will miss the bike and want to buy it back?
Karmic relief, no?
« Reply #12 on: September 19, 2007, 04:47:24 PM »
Karmic relief, no?
What all of the posts sum up to is would you rather burn or freeze to death?
Offline motomotard
    • GoGo Garage
« Reply #13 on: September 19, 2007, 05:16:58 PM »
i tried to chip the jb weld off, but its not going anywhere. so i just pulled the whole pan, it was messy but whatever.
im gonna replace the pan and gasket. definitely the easiest thing to do. when i pulled the pan off the gasket fell apart, so now it just sucks that the bike has to sit until i get the new pan.
any suggestions on where to get the gasket?
« Reply #14 on: September 19, 2007, 05:49:36 PM »
Honda may be able to provide you with one. You would be surprised at the parts available.
Offline mkramer1121
« Reply #15 on: September 19, 2007, 05:57:24 PM »
Or, you could make one!  That is, if you have a scanner.  This is Bob Wessner's tip so don't give me credit.  Clean the pan thoroughly.  Place it on your scanner.  Scan, and print.  Trace where the gasket sits onto a sheet of gasket material bought from an autoparts dealer.  Punch the holes and Voila!  You have your new gasket!
antiq
« Reply #16 on: September 19, 2007, 06:19:32 PM »
Or you could do it the old school way. What I used to do was use a ball peen hammer but since this is aluminum use a small plastic hammer. Just put the gasket material over the pan and hammer gently on the edges of the pan through the gasket material and at the bolt holes. You may want to round one plastic head like a ball peen for the bolt holes. It may not cut the material all the way through but a sharp knife will complete the cuts and voila new custom fit gasket.
Offline Odge
« Reply #17 on: September 19, 2007, 06:25:14 PM »
Everything gets blamed on this PO guy.
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
« Reply #18 on: September 19, 2007, 06:58:45 PM »
Honda should still make the gasket.
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
Offline motomotard
    • GoGo Garage
« Reply #19 on: September 19, 2007, 07:16:48 PM »
the gasket is like $10 from honda
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #20 on: September 19, 2007, 07:28:01 PM »
The idea was not original to me, but thanks for thinking it was. :)
Offline canyon750
« Reply #21 on: September 19, 2007, 07:29:05 PM »
I don't want to worry you but when you run into "fix it" jobs like this there usually is another horror awaiting you somewhere else on the bike.  I was just helping my friend with a fuse blowing issue on his 83 Goldwing when i found speaker wire was used to wire the accessory turn signals along with clamp style jumpers to power them!   :o  I also found that when the APO removed the old radio (remember this was a Goldwing) he left the in-line fuses in the lines and just cut the ends off! The bare ends were shorting against the frame right through the fuses!
I'd take a look around and make sure your not missing a nightmare waiting to happen.  My $0.02 USD.
1976 CB750F (Modified!!)
2005 Honda VFR800 (Burnt & gone...)
2007 Honda VFR800 (RWB!)
2019 Yamaha Tracer 900 GT
SOHC/4 #846
Offline mkramer1121
« Reply #22 on: September 19, 2007, 09:14:32 PM »
I know you could buy one...But I posted it caught some of us like to do it ourselves!  Not really, but I thought it was cool.
And Bob, you enlightened me to it, so it is now forever your idea in my book!
Offline blackhog02
« Reply #23 on: September 19, 2007, 09:45:24 PM »
Damn you must have bought your bike from the same guy I got mine from.  On mine I pulled the plug and no oil came out. I was like what the hell.  Then I pulled the pan and made a huge mess in the garage.
the PO has JB welded on the inside of the pan all around the drain bolt because it had been over tightened and it was cracked.   I ended up replacing the pan and getting a new gasket from the Honda dealer.
Offline jonbuoy
    • My rebuild:
« Reply #24 on: September 19, 2007, 10:03:58 PM »
JB weld will soften up and crack with a blue flame from a  blow torch.
