Author Topic: Purple vs. Green  (Read 1161 times)
Offline KB02
Purple vs. Green
« on: October 13, 2007, 08:04:20 AM »
Well, I stopped into one of my local Auto parts stores the other day to see about getting some SImple green. The guy said he didn't have any, but did have some stuff called "Purple Power" that would do the same stuff.
Here is a picture of the tarnished bowl, slider and top off of one of the K8 Carbs I am working on:
Before:
This is a pic of the bowl after a five minute soak:
And here is the aftermath with a little scrubbing with an old toothbrush:
I figure it's not too bad for $7 US for a gallon jug.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline joeb
Re: Purple vs. Green
« Reply #1 on: October 13, 2007, 08:12:59 AM »
They look like my carbs did when I recued my 78 Supersport nice job on the slider and bowl. Be sure to check the accelerator pump diaphram for pin holes.
Offline heffay
« Reply #2 on: October 13, 2007, 10:11:57 AM »
they sell this other stuff called carb cleaner  ;)
glad you found a working concoction... when i get to the 400f carbs... maybe i'll give it a try.
right now though, i'm gonna head out to the garage and dremel the combustion chambers, yay.
Offline lhemrick
« Reply #3 on: October 14, 2007, 08:09:24 AM »
"Spray Nine" is some good stuff also but the trick is finding it. Here is a couple of pics of my carbs after I bead blasted the top covers and the bowls and polished the outside. Do you have access to a blaster? Some really fine glass beads are the bomb!
Lynn
Don't give up; Rust is only Temporary!
77 Honda CB750
70 Honda CB350 twin
71 Honda CB350 twin
72 Honda CB350 Four
72 Honda CB175
81 KZ550C2
81 KZ750H2
82 KZ750M1 CSR
84 ZN700 Shaft
