Author Topic: Popping at idle  (Read 1396 times)
Offline 6adan
Popping at idle
« on: October 21, 2007, 12:29:46 PM »
  I have a popping on my 750 after warm up, 4 into 1, K and N air filter in stock airbox. This seems to have started or gotten more notesable after going from 91 to 87 Oct gas. Any ideas ? Thanks Dannie
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Re: Popping at idle
« Reply #1 on: October 21, 2007, 01:32:54 PM »
Is the poping from intake or exhaust (or knees) ?
Lower octane fuel burns a bit hotter, more aggressively (ignites at a lower temperature, faster flame front travel) than the higher octane.
When was your last complete tune up?
Has the jetting been changed since the 4 into 1 change?  What carb set up are you running?
Offline 6adan
Re: Popping at idle
« Reply #2 on: October 21, 2007, 05:33:08 PM »
 Popping from exhaust( knees pop also but different sound)
  New plugs about 500 mi. timing and valves about 1000.
  Jetting is stock for 1970 750.
  Needles had been set at second from top, I moved to center but that did not seem to help
 If you think a tune up would do it ,I will do it. Thanks again Dannie
Re: Popping at idle
« Reply #3 on: October 21, 2007, 11:06:27 PM »
Ok, Exhaust poping...
Is this on Decelleration?
Are your pipe-to-head gaskets leaking?  Or, any leaks in the exhaust that would let in oxygen to ignite a fuel rich environment in the pipes?
What do the deposits look like on the plugs?  Compare yours to:
http://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
Let us know...
