Author Topic: Shed-in-a-box, anyone here ever use anything like it?  (Read 2339 times)
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
« on: December 02, 2007, 12:58:41 AM »
I just caught wind that I either need to do two things. Get a storage space (really expensive option) or find a reasonable outside storage solution. I'm waiting to hear on a few leads for a workshop type set up, but for now I've been trying to figure out the best I can work with. I have a bunch of project bikes- some run, but need TLC and a few others are just waiting their turn. Unfortunately I live in MN and blizzards bring out the need for space (I played nice guy- and mr.compromise). I didn't think i'd be loosing an inch of my space ever, but it happened.
I was looking on northern tool and it seems that they have a few things that I could use to protect the projects from the wet snow- like this:
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200318435_200318435
I could just go with a well done cover and then tarp, but I thought this might work a little better and look less like crap. I'm mostly concerned about it flying away or being a waste of money- again, who knows!
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
Offline boatsdickson
  • 1978 836 K8
Re: Shed-in-a-box, anyone here ever use anything like it?
« Reply #1 on: December 02, 2007, 04:29:47 AM »
When I think of an outbuilding for storage or whatever, this style comes to mind. Ive seen all sizes and styles and prices around here, but I cant offer a good website forya. Seems like theyd be easy to build but it sounds like your racing the season......  8)
These pics are what I mean. Think the small one was 400 - 500 bux....
"No. We're all our own prisons, we are each all our own wardens and we do our own time. I can't judge anyone else. What other people do is not really my affair unless they approach me with it. Prison's in your mind. Can't you see I'm free"?  Testimonial of Charles Manson
Offline kirkn
« Reply #2 on: December 02, 2007, 04:56:04 AM »
Two houses ago, I bought a 10x16 Ted's Shed.  $3500 (10 years ago) and they delivered it, leveled it, and tied it down.  Wood frame construction and metal (tin) walls and roofs.  Pressure treated floor and floor joists.  8' wide roll-up door, 7' tall inside.  Truly a Cadillac of sheds, but it withstood direct hurricane strike to West Palm Beach, FL where we lived at the time.  Still there, going strong!  If you can cough up the initial purchase, this is the way to go.  It came pre-wired for electricity, although I never got around to running power out from the house.
At our last house, I built two of those tin buildings.  One was 8x10 and the other was 10x12.  Came in boxes from Lowes.  $199 and $299, respectively.  Both had sliding double doors.  The small one had a simple sloped roof but the bigger one had much higher ceilings with the Barn-style roof line.  Much nicer!  Both withstood the 3 hurricanes of 2004 that hit Orlando.  However, both tended to leak at the roof screws after time, and at the wall-to-floor joints.  The roof leaks weren't bad, because they didn't drip, they just allowed water in that would run down the underside of the roof, down the walls and puddle on the floor.  However, it was always very humid in those buildings, and I kept my dirt bikes and my sons' dirt bikes in them, they'd get mildew or moisture-induced corrosion.  And, nothing water-sensitive (bags of cement or fertilizer) could be kept directly on the floor.  However, it was great for lawn equipment, boat paraphernalia, lawn chemicals, patio furniture, etc.  In the larger one, I built some light-duty rafters that allowed some lightweight storage (water skiis, fishing poles, etc).
The house we're in currently, I'm building a 12x20 shed using 'conventional' wood-frame construction and poured concrete floor and 8' garage door.  We're just drawing up the plans now.  Should be cheaper than the $3500 quoted for a smaller 10x16 Ted's Shed, and I'm hoping it'll be a fun building project for the boys and me.
Good luck with whatever you choose.
Kirk
Offline medic09
« Reply #3 on: December 02, 2007, 07:07:35 AM »
My wife's chicken coop/toolshed is a thing she got from Home Depot.  It looks decent.  It is pretty much weather-tight.  They delivered, levelled, and 'installed' it where we wanted it.  Have had it now about 4 years, and it looks to last a long time.  It has two widows and a pretty large door.  They make them in different sizes.  It is just a shell, but one could easily insulate it and wire it.  We just run a long extension cord out to it to keep the hens water warm during the cold months.  Don't recall what size it is, but it is definately big enough for two bikes and some tools.  This one was about $800 including delivery.
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline 333
  • Time for change
« Reply #4 on: December 02, 2007, 07:36:40 AM »
I went the way Kirkn did and had a shed built onsite, but it sounds like you might not want to go all that way.  I'm thinking a cloth-like building might not stand up to heavy snows..I've seen(and Northern might be where)an aluminum awning style.  It does not have sides, but poly tarps could easily be made to make walls.  And I know Northern has a method for keeping whatever you get from blowing away.  They are a corkscrew type of deal you screw into the ground and tie off the canopy.  I got a set to keep my Easy-up from blowing off the beach.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline mark
« Reply #5 on: December 02, 2007, 07:55:38 AM »
I've used this sort of thing before.....
Northern wants $180. It covers 10X20ft.
It definitely needs tie-downs in windy areas.
Happy trails.
F you mark...... F you.
Offline mikedialect
  • cbjunky
« Reply #6 on: December 02, 2007, 08:43:37 AM »
unfortunately I can't have a permanent structure. I do not own the place I live in. It sounds like good tie downs will do the trick. I'm out where it would be pretty often, so I would probably brush it off after each snow. Anyways, I'm just sort of verbally (well, writing) justifying the purchase. I was just wondering if anyone had actually seen one and they thought "what crap!" or something along those lines.
SOHC4 Member#44153
Offline miles nowhere
  • motorbikeist
    • Miles Hunsberger Tattoos
« Reply #7 on: December 02, 2007, 08:54:43 AM »
the one you posted doesn't look like it will hold up to a whole lot of snow..I've been seeing adds in the paper for heated storage spaces for super cheap..I think they were in burnsville or some 2nd ring suburb..
78 cb 750k8, 78 cb 750F3, 78 cb 750F3, 74 cb 750k4
Offline mikedialect
  • cbjunky
« Reply #8 on: December 02, 2007, 09:45:14 AM »
yeah, I've been looking for a space where I could maybe have a small shop in the area, too, but it's not panning out. I would rather not pay a storage place, but it may come to that. It's the damn ideology in me. I just want that little home away from home work space! or a little spot near by that I can leave all the bikes that I'm not working on.
SOHC4 Member#44153
  • motorbikeist
« Reply #9 on: December 02, 2007, 11:19:59 AM »
there are still a bunch of affordable warehouses in North East, as long as you stay away from the shmancy art collectives.  In the past I've found people that sublet me a garage sized corner of their rented warehouse space for cheap...
Offline mikedialect
  • cbjunky
« Reply #10 on: December 02, 2007, 01:06:16 PM »
I just got a call back from an old pal. Looks like he's going to let me set up a small shop in his warehouse. So, I can have all of my bikes there with a place to tear down junkers I find. That phone call pretty much made my year! There might be a time in the near future where I don't have engines in my living room :)
SOHC4 Member#44153
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #11 on: December 02, 2007, 02:33:46 PM »
They call that marriage.. unless of course you already are, in which case you have a very understanding SO. ;)
Offline mikedialect
  • cbjunky
« Reply #12 on: December 02, 2007, 03:17:44 PM »
haha. No, when I was with my "former roommate" (nice way of saying that I think :) ) I had one bike, no engines and no time or money. I'm single and I have 10 bikes and 3 engines in my former dining room :)
SOHC4 Member#44153
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #13 on: December 02, 2007, 03:21:49 PM »
        Something like this is what I've got some of my "Projects" stored in. Except that I gave $99 for it and it just had a tarp on top. I added tarps around the sides. Mine is a 12 x 20 and has taken a pretty good beating over the years. Lately, I got a swingset frame, fixed it up and, after nobody was using it, took everything off of it, threw some tarps over it and it will cover about 10 bikes.
         Mike, glad you got a decent place to set up in. ;)
Member # 1969
Offline 333
  • Time for change
« Reply #14 on: December 02, 2007, 03:31:28 PM »
Glad that warehouse of your friend came available.  Those storage places usually say "no gas or solvents", some even frown on vehicles with batteries.
Offline mikedialect
  • cbjunky
« Reply #15 on: December 02, 2007, 03:41:49 PM »
me too!
I used to work for a company that owned several storage buildings. I ran their parking lot operation (where the new twins stadium is going- that was a mess) and I talked to the folks who ran the units quite often. They said that the less they know- the better. At least I'm not storing stolen AK's or a make shift meth lab (oh the stories I have!!). They have to put those signs up because they then get cheaper insurance :) I guess some places might care more, but I always figured that business was mostly about collecting checks from tenants rather than working.
SOHC4 Member#44153
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #16 on: December 02, 2007, 04:30:00 PM »
Actually, the warehouse owner may also benefit from your presence (along with your bikes). Presumably you will be in and out from time to time, evenings or weekends and that activity might discourage, hmm, shall we say bad folks from lurking, breaking in, etc. In any event, glad it worked out, sounds like a great option.
Offline rbmgf7
  • 2>4
« Reply #17 on: December 02, 2007, 06:11:47 PM »
my buddy has one of those plastic 8x10 units you can buy at sams club. comes wrapped up and can fit into the back of a fullsize truck. once together it looks like a large kiddies clubhouse and has held up to almost 4 years of missouri weather.
it's not bad. if you're less than 5' or born a hunchback you can work on one bike inside.
take a look at sams club website. i think i saw a unit on there similar to the one you have linked but also has a door.
