Author Topic: Rear turn signal mounting  (Read 1508 times)
countrygreg
« on: December 04, 2007, 05:14:20 PM »
I have a 1975 cb550 that came without turn signals. How hard can it be to order stock used turn signals and bolt them in?  The fronts came and bolted in no problem. I have no idea how the rear turn signals are supposed to mount up. They came with  "U" shaped brackets with 2 holes in them. This matches the turn signal mounting flange. The fender has one hole in it with a welded nut on the back side. The Honda parts book seems to show "U" shaped brackets. What am I missing?
Re: Rear turn signal mounting
« Reply #1 on: December 04, 2007, 05:41:55 PM »
Does this help?
wilinfla
« Reply #2 on: December 04, 2007, 05:49:47 PM »
Does your 75 have a garb bar? My 76 CB550K has a grab bar that the turn signals mount to.
        Will
countrygreg
« Reply #3 on: December 04, 2007, 07:51:36 PM »
Thanks so much guys. I am missing the grab bar!
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #4 on: December 04, 2007, 08:32:45 PM »
You can mount rear turn signals, with no grab bar, if you are into doing a bit of fabrication.  ;D  This was the result of my winter projects, last year. ..
(Ford Model "A" taillight replica in stainless + vintage big truck driving lights for turn signals.)
Here you can see the aluminum piece I made to mount the signals. There is that flat part of the fender behind them that had to be hammered a bit flatter. Holes were then drilled all the way through both parts for mounting.
How the same lights were mounted on the front:
These mods were pretty fun - a lot better than the elephant ear after market turn signals the APO had mounted all crappy.  8)   I also wired them so I can run just the front, just the back, or all four as driving lights - very handy when its very foggy/rainy out (which here in Orygun, it tends to happen)
« Last Edit: December 04, 2007, 08:39:13 PM by MoTo-BunnY »
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
