Author Topic: Old motorcycles, in particular Japanise bikes, vs. computers!  (Read 666 times)
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« on: January 05, 2008, 12:13:07 PM »
I have a Sony Handycam that I also use to take digital pics.  It is only 1.5 meg but is fine for shots that I post here and other places.  Up until 2 months ago it was easy to just plug in to any of my PC's and access the pic folder. Now it does not work no mater what I do.  I can't post pics of my shop, my other bikes or how I intalled an electronic oil pressure gauge on my CB350F.  %^*%&$&$^ technology!
I wish everyting worked like the CB's do:
No need to upgrade the device driver when you change brand of fuel or oil.
In fact there are no drivers needed (except for me, the main driver).
No driver needed so that the head recognizes the carbs.
No driver needed so that the carbs recognize the fuel tank.
You do not have to worry about viruses invading your system.
Wire, tape and a pair of Vise Grips can repair most things.
And the open highway is alot more interesting than the Information Super Highway.
Ok, I feel better.  Going back to the shop to work on the bikes.
« Last Edit: January 05, 2008, 09:09:00 PM by kslrr »
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
Re: Old motorcycles, in particular Japanise bikes, vs. computers!
« Reply #1 on: January 05, 2008, 12:18:57 PM »
Changing from application
GirlFriend 6.0 to Wife 1.0
Last year a friend of mine, system administrator as myself, changed the application GirlFriend 6.0 by Wife 1.0 and found that the update was not very successful. First of all Wife 1.0 leaves very little system resources for other applications, not only this, but he has also realized that Wife 1.0 is a prolific processor of Babys 1.x, which are additionally consumers of valuable resources.
There was no mention of this particular fact neither from the product manufacters nor in the warranty, altough some colleagues had inform me that this was expectable, due to the nature of the application.
But surprises didn't end up there, additionally Wife 1.0 configures itself so that it always starts when the system is initialized, from where it can monitor the rest of the processes.
My friend is noticing that some applications like: NightOfPoker 10.3, BeerParty 2.5 and PubNight 7.0 no longer can be run, because Wife 1.0 locks the system when they are selected (even so they always worked fine before).
During the installation, Wife 1.0 installs automatically services not desired, like MotherInLaw 55.8 and the DEMO version of BrotherInLaw. The most outstanding effects of these services are the progresive and daily degradation of the system.
My friend is very seriously considering to change the version of the application Wife, but there are some features that he would like to be added to the next version (Wife 2.0), these are:
A "Forget me" button and another for minimizing.
A new option that allows to install Wife 2.0 with an option of "Desinstall at any time", without losing the cache and other valuable system resources.
An option to run the network controller in "promiscuous" mode, that allows to the system to try shareware version of different applications, to have a better knowledge of the market.
I have decided to avoid all the headaches associated with Wife 1.0, continuing with GirlFriend 2.0. Even so, I have found many problems. Aparently you can't install GirlFriend 2.0 on GirlFriend 1.0, you have to desinstall GirlFriend 1.0 first. Additionally, aparently, the versions of GirlFriend have conflicts to share the same I/O (Input/Output) port. The technical support has said me that it is a known bug and that they are looking for some way to bypass the problem, because it seems to be implemented in the kernel (heart) of the application and it is not a good idea to change it.
Even worse, the program to desinstall GirlFriend 1.0 doesn't work very well, leaving unwished traces of the application in the system. Another problem: all the versions of GirlFriend continually give anoying messanges about the advantages of changing to Wife 1.0. After talking again with the service they suggest me to ignore those messages, and when I point that for that solution it was not necessary to phone them, they go back again on the explanation of the former problem (bug in the kernel).
WIFE 1.0 INCOMPATIBILITIES: If you try to install Lover 1.1 before desinstalling Wife 1.0, this erases the files MS-Money, and after it desinstalls itself. Then Lover 1.1 won't install, claiming that system resources are too low. To avoid this effect, try to install Lover 1.1 in a different environment and never run a file transfer application, like LipStickSpot 6.0. Also try to avoid renting applications, because it's known that they can transmit viruses that can affect Wife 1.0. Another solution is to run Lover 1.1 through a network provider with and anonimous name. Once again, avoid viruses that can be accidentally loaded.
IMPORTANT: More problems have been detected with Wife 1.0
Found real friends here !!!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: January 05, 2008, 02:12:31 PM »
 ;D ;D
« Reply #3 on: January 06, 2008, 07:46:30 AM »
You are right. Let's get back to fundeimentals:
