Author Topic: Ignition Analysis: Honda's coils  (Read 86943 times)
Offline markjenn
  • CB750K1, CBX, RC30
    • Whizmo and Gizmo
Re: Ignition Analysis: Honda's coils
« Reply #75 on: July 25, 2008, 04:34:41 PM »
Maybe it's somewhere in this thread, but I'd like to get a better handle on exactly how much extra current my system load is with 3-ohm vs. 5-ohm coils.  (I have a K1 that is stock except for a Dyna S and 3-ohm coils - no problems whatsoever keeping the bike charged in a couple years of riding like this.)  Back of the envelop, it would appear that the extra current per coil is going to be 1.8A (assuming 13.6V nominal) or 3.6A total.  But this is continuous and the coils are going to have a duty cycle.  Further, I assume the inrush current is higher.  Any idea what the average total extra current load is?
I rode around for years through midwest winters in the 70's and 80's on several 750's with electric vests pulling 5A or so without the slightest hint of a charging problem.  So I don't think the system is that much on the ragged edge.  Nevertheless, I don't mind the point system and would go back to stock if this extra current draw is a serious concern.
- Mark
« Reply #76 on: July 25, 2008, 07:28:56 PM »
- Mark
Mark:
It works out like this:
The Dyna triggers' OFF time is 27% of the points' OFF time, so the coils draw current for 83% longer. This works out to (.83 * 1.8A * 2 coils) = 2.988 amps extra current overall for your system.
When the bikes are young and all the connectors are good, splices have not been heated over long periods, and a high quality battery is present (batteries like that are hard to find today, BTW) and a sealed beam headlight is used, this is not a significant increase. The 750 has about 4 amps available, with the lights on, in this situation.
But, enter an 1157 taillight bulb (extra 0.5 amp), heated alternator contacts (.1 ohm typical, losing .2 amp apiece x 6 contacts = 1.2 amps), heated splices and old bullet connectors (mine measured .47 ohms this summer, battery-to-coils loop), and old, corroded grounds from neglect, a halogen headlight, and the margin drops to 1-2 amps over stock. The smaller bikes don't have the margin to begin with, and trouble appears right away. Oh, and the fuseholders themselves: these just corrode into high resistance until they start heating the fuses, because the coatings flake off, like mine did, even with good care. This introduces another drop of amperage.
The whole cure is to replace all parts with correct ones and and renew connectors, but most owners can only attempt this with a whole harness replacement, as they lack the tools needed otherwise. When this doesn't happen, the results are what we so often see on the forums.
« Reply #77 on: July 25, 2008, 08:43:17 PM »
Hi TwoTired
     I wondered if there was a way to tell which coil was which. I compared the coils on my 400F1, 550, & 750F1. The marking on the coils is, 400F1 FL703-12V57 F, 550 ( not sure which 550 ) FL703-12V 68L & FL703-12V 67L, 750F1 FL703-12V G. Tomorrow I will check the resistance of these coils.
          TomC in Ohio
     Which I did but forgot which thread I was on. All of the above coils measured 4.5 +/- 0.1 ohms. The 750 and 500 coils may have been different when the manuals were written. But by 1976 all the SOHC4 seem to be using the same coil, except for wire length.
            TomC in Ohio
I have not done extensive testing across all models of Honda coils.  The only coils I have off the bike right now are from my 74 Cb550.  Their numbers are FL703-12V48 C  (2-3 coil) and FL703-12v48 B (1-4 Coil).
The way the numbers are cast into the coils, show distinct variation in the size and shape of the 48 in the number.  This leads me to believe this is a batch number or more likely a date code of some type.  Perhaps batch 8 in 1974?
Anyway, the number is clearly cast from a mold which does not have to change in order to encapsulate whatever coil winding arrangement was placed into the machine.  Remember these coils were made to Honda specifications by TEC.  I've no idea what their convention was fro marking the coils or if "batch numbers" were used to identify internal characteristics or make up.  Anyway, TEC's final product would be delivered to Honda where they would assign the Honda part number for distribution to the appropriate assembly line.
I don't know that WAS done this way.  I just observe that it COULD have been done this way.
I guess the point is, that I don't know that the numbers on the coils have a known correspondence to the Honda part numbers, outside of Honda record keeping.
But, I measured the coils anyway.  I used two DMMs.
Bear in mind that thee coils were replaced because the there is an intermittent wire on the 2-3 coil.  I have to wiggle it to get a reading.  And, it's accuracy is suspect.
With the Fluke 0804 I measured the 1-4 coil to have a 14.95K secondary and a 4.8 ohm primary.  The meter leads account for .3 ohms of that reading.  So, the primary measures 4.5 ohms.
With the Fluke 0804 I measured the 2-3 coil to have a 16.90K secondary and a 4.8 ohm primary.  The meter leads account for .3 ohms of that reading.  So, the primary measures 4.5 ohms.
With the Fluke 73 I measured the 1-4 coil to have a 15.02K secondary and a 4.6 ohm primary.  The meter leads account for .2 ohms of that reading.  So, the primary measures 4.4 ohms.
With the Fluke 73 I measured the 2-3 coil to have a 17.60K secondary and a 4.6 ohm primary.  The meter leads account for .2 ohms of that reading.  So, the primary measures 4.4 ohms.
I'm not sure about the magnitude difference would be between an 380 turn primary and a 420 turn primary.  If I knew the length and gauge of the wire, I could make a pretty close estimate.
But, I am assuming it would be pretty small and possibly difficult to measure, without a very sensitive meter.  Probably better to infer it, by applying a known precision voltage and measuring the Vdrop across it, while noting the current being drawn.  Just a calculation, then.
Seems likely there would be a more significant difference in the secondary resistance. This would be smaller gauge wire than the primary, offering more resistance per length of wire, and 2000 turns difference ought to show a significantly different resistance.
I'll try to remember to measure and collect data on my other coils, next time I have the tank off for access.  Maybe Honda did change to a universal coil.  Wouldn't be the first mistake I've found in the books.  I'm just not quite ready to make that conclusion.
« Reply #78 on: July 25, 2008, 08:57:56 PM »
Great detective work, TT!  :D
Offline Hito550E
« Reply #79 on: July 29, 2008, 10:47:28 AM »
Anybody have a part number for Dyna 5ohm coils?
« Reply #80 on: July 29, 2008, 11:05:33 AM »
Likely only an engineer can appreciate, I'm afraid.
But, thanks!
Offline starkmojo
  • Yes I am tall...
  • Wow that bike is Orange, but I kinda like it.
« Reply #81 on: August 09, 2008, 11:29:18 PM »
First off thanks to all the folks who know what they are talking about regarding Honda ignition systems. Reading this (and the other related threads) has been a big help to me. My own issue is that the original spark plug wires on my 74 cb750 are cracked... and when I looked at the manual I was surprised to learn that they were attached to the coils? this irritates me- as I have replaced a lot more wires then coils in my time (on VW busses). So when I looked into after market alternatives where the wires could be replaced without the coils, I came across Dyna coils, Dyna S electronic ignition and ultimately this thread.
For trying to figure out what to do within my budget, while still allowing me to upgrade later I came upon this idea- to get the Dyna 5 ohm coil, supression wires and continue to run points fro the rest of the year ( the PO left me with a couple sets of points anyway). That corrects the current problem (shot wires) while still allowing me to make changes in the future to get rid of points. I personally found electronic ignition to do wonders on VWs for increasing there performance and gas milage, so it is something I am interested in doing on my bike, but only after I get more important priorities (like new rubber for where the bike meets the road).
Any suggestions? ???
twoold to give up
twotired to care..
« Reply #82 on: August 10, 2008, 07:20:20 PM »
There's little doubt that the electronics boosts the spark performance: just ask anyone who's installed one of mine!  ;D
It is a sort of bummer that the Honda wires aren't replacable, but then, mine typically lasted 10 years per set or more: my cars don't get anywhere near that kind of life,  "Lifetime Warranty" notwithstanding (just try to collect on one of those: I'm still waiting for 2 of the Autolite warranties to come back to me, 3 years later.  >:( ).
« Last Edit: October 05, 2008, 08:44:39 AM by HondaMan »
Offline Cannibal
« Reply #83 on: August 10, 2008, 07:30:08 PM »
Hondaman, what would you recommend for replacement coils for someone like myself that still has stock coils and HM ignition?
Also, where do you get those nice terminals that come with the HM ignition to hook it up? I'd like to eventually go through and replace all of my terminals with those.
Steve
Offline starkmojo
  • Yes I am tall...
« Reply #84 on: August 10, 2008, 07:52:48 PM »
10 years? wow the most I ever got out of my bus plugs was 3.
The ones on mine look stock- and 34 years old. The spark is weak when tested. also lower then expected gas milage so coils first.
EI and chrome stuff later...
twoold to give up
twotired to care..
« Reply #85 on: August 10, 2008, 08:15:35 PM »
Stark: change those condensors first. Typical low-spark scenario: leaky condensors.  ;)
« Reply #86 on: August 10, 2008, 08:18:34 PM »
Steve
On any SOHC4, you could use the Dyna 5-ohm coils, straight swap. On a 750, you could use the 3-ohm coils and HM ignition, but with the Resistor Pack.
On a 500/550, you can also use this 3-ohm combo, but only if the headlight is near stock wattage and the taillite is a 1034 bulb, or it will start running out of amps.
For those terminals: look at vintageconnections.com . Del sells whole kits for these bikes, with a terrific crimper for only $35 (or so) that's worth at least 3 times that much, for use on these parts. He's REAL good to deal with, a straight shooter, and good prices for top-flight parts. I bought several connector kits for the Hondaman Special(s) wiring harnesses: he even sells the black sheathing (better than OEM quality) to recover your harness. Great stuff!
« Last Edit: August 10, 2008, 08:31:26 PM by HondaMan »
Offline starkmojo
  • Yes I am tall...
« Reply #87 on: August 10, 2008, 10:24:56 PM »
Points and condensors are a team- wouldn't change one without the other. Or one pair without the other- I also neglected to mention that the plug wires are cracked and that is why I started thinking wire replacement...
The PO gave me three sets of points and condensors, three oil filters... all labeled "CB750 74..." even though he only had one bike. Along with every stock item he had pulled off the bike in the 33 years he owned it. God I love buying stuff from old guys.
So the coils, wires, connectors, plugs are all ordered. To be changed with the points and condensors, after a valve adjustment and along with an oil change. when I pulled the fairing off I saw some short lengths of wire that had been used as splices to the fairing- I just put bullet connectors on the splices, but I think I will go back and remove the splices and put new terminals on the original wiring, along with cleaning up the wiring of the tail lights. The bike is well cared for,  but some of the wiring is neglected, and doing a full tune up is a good way to get to know your way around a motor.
They should all arrive the day before I get home from work- can't wait to bring the coffee pot out and set it on a milk crate and start doing my thing- bringing down the property values in the hood!
« Last Edit: August 11, 2008, 04:34:15 AM by starkmojo »
twoold to give up
twotired to care..
« Reply #88 on: August 11, 2008, 05:30:30 AM »
 :D  Sounds like fun to me!
If you do mostly in-town driving, you'll likely find the plug foul earlier than they should. This is due to NGK stopping production of the D8ES-L plug, a long-tipped plug in between the D7E and D8E heatrange: this plug was made expressly for the CB750. The D7 is OK in town, a bit too hot for hiway, and vic-versa for the D8. All is not lost: NGK's parent company still makes this heatrange in their Nippon Denso (ND) X24ES-U plug, my personal favorite. It's perfect for all but full-Interstate trips at 80 MPH (even then, I've used it with no problems). In winter riding, I use it's hotter sibling, the X22ES-U (similar to D7).
DFCruiser77
« Reply #89 on: October 04, 2008, 09:46:46 AM »
HondaMan,
I recently bought a 77 750F, discovered it has a DynaIII ignition, but still has stock coils. (so I don't have old points plate, etc) I'm not clear from reading posts; would you suggest 5ohm Dyna coils?  and would your resistor pack be needed?  plus you mention LED brake  light bulb..... but not the 1157 vs 1073?  maybe you were referring to a different bike than 750.  I do need to conserve power, so I can put on Halogen HL, so am open to all ideas here, I'm convinced the more you stand out...
I've just been refurbishing since purchased a few weeks ago, and put about 100miles on it, before finding the battery going down (wouldn't turn over motor... )
appreciate your input, or anyone else with experience with this setup
« Last Edit: October 04, 2008, 03:10:05 PM by DFCruiser77 »
« Reply #90 on: October 04, 2008, 03:24:01 PM »
You know you can delete any portion of your post mate, so you could have taken the "oil in alternator" part out yourself?
Anyway, the Dyna III (that Dyna no longer makes, sadly) is a great ignition, but needs Dyna 3 Ohm coils to get the most out of it. I had one on my first F2 and it was the hottest, fattest spark I've ever seen while not wearing a welding mask, and my old bike would fire up if I just waved my thumb over the starter button.
The trouble is that in the US with your automatic "lights on" laws, your ignition and headlight are writing checks that your charging system can't afford. The best thing you can do is swap it out for a points plate and one of Mark's (Hondaman's) ignition amplifiers, they draw no additional power from your system, but will make your bike start easier, (with less than 12 volts in your battery, unlike the Dyna) accelerate faster, and get better fuel economy than points alone. You probably won't notice any real performance improvement over your Dyna III, apart from your battery not going flat all the time.
I've got three of Marks ignitions, and can tell you that the build quality is excellent, they're easy to install, and are worth at least twice what he's selling them for. If you decide to buy one, I'll buy your Dyna III, we can turn our headlights off here in Oz, so it's not so much a problem as it is there. Cheers, Terry. ;D
DFCruiser77
« Reply #91 on: October 04, 2008, 05:44:42 PM »
Thanks Terry, saw edit button too late, but got it fixed.
Will check with Mark on his system... will let you know if/when I pull off the Dyna III
mike
« Reply #92 on: October 05, 2008, 08:57:23 AM »
HondaMan,
The taillite bulb can be either 1034 or 1157 on a 750, as it has enough extra power for the 1157. It seems that today's 1157 bulbs draw considerably more current than they used to, though, probably because most of them are of Chinese manufacture. They usually make products that LOOK like the original, but seldom meet original specs...  :-\
I was working on the LED taillite thing when I lost my last job (early this year), and haven't had the extra $$$ yet to pursue a good solution. The LED 1157 bulbs out there, in any form, are not as bright as the regular bulbs. There's a solution, but it will have to be built. No one makes a good off-the-shelf solution right now. It's one of my winter projects...
If you have the 5-ohm Dyna coils, or even stock Honda coils, the Dyna III will make good spark (better than points), but at the cost of an extra amp (a little more than an amp, actually). If you use a 50w/60w halogen headlight, it will just fit in the 750 power budget for 'lights on' riding (HIGHLY recommended for safety reasons) with the standard tail bulb, if you're not stuck in stop-and-stop traffic 100% of the time. Also, cleaning the connectors and grounds, and making sure the fuseholders are good (not corroded or rusty) will really help. Don't overlook the alternator connector: it's a common source of losses because the high-pressure car wash soap hits these blades and corrodes them. They can be easily scraped clean, like the grounds, and a drop of oil will help prevent the next round of corrosion.
My ignition will give you back about a full amp in this situation, overall.
eldar
« Reply #93 on: October 30, 2008, 10:52:29 AM »
OK I do not do stop/go traffic but I have the dynas and the h4 bulb and all the standard bulbs. I have no issue with charging at all. I wonder if honda didn't increase the output on the later bikes.
Offline papp101
« Reply #94 on: October 30, 2008, 12:41:07 PM »
I'm thinking about putting 79cb750 coils on my 71cb500. Should I use two 1 ohm resistors in that case to go with my stock points?
« Reply #95 on: October 30, 2008, 06:32:24 PM »
The alternator was the same as the earlier bikes (210 watts), but the later rectifiers were better, wasting less power. So, the electrics did fare better, later. Simply replacing the older rectifiers with the newer ones fixes things right up. Installing a set of low-drop rectifiers (Schottky type) adds almost 1/2 amp extra capability because the heat losses over the diodes drops considerably. (One of my future endeavors  ::) .)
« Reply #96 on: October 30, 2008, 06:34:36 PM »
No need for resistors: the coils interchange fine. I've been running a set of CB500 coils all summer, this year, on my 750 - because my 750 coils were 37 years old, and one of the wires fell out of one of them (!). And, I had the 500 ones handy.
« Reply #97 on: October 30, 2008, 07:35:21 PM »
Aren't 79 750 DOHC4 coils lower ohm coils?
Offline Pinhead
  • 1979 CB652-ST
« Reply #98 on: October 30, 2008, 10:53:12 PM »
The '79 CB650 coils are 2.5 ohms, I believe. I also think the DOHC 750s use the same coils....
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline Soos
« Reply #99 on: October 31, 2008, 12:12:10 AM »
Yes the DOHC 750/900/1100's all use the same coils an the '79-82 cb650's.
The 3 sets of used 650 coils I have measure from 2.4 to 2.6 ohms.
the 1 set of '79cb750 DOHC coils I have have the same part# oin them as well as test at 2.5 ohms.
Interestingly enough kawasaki GPZ600(aka ninja) '85 coils test at 2.4 ohms as well.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
