Author Topic: help help with a fuel problem or running  (Read 3060 times)
750FSS
« on: July 29, 2005, 03:28:54 PM »
hey guys ,
on  my 1976  750f i just bought it from a guy a few days ago it was running fine with no bogging down , idle a little high,(1500 rpm )   but i took it out last night and it was bogging down and dieing out. i pulled the spark plugs and they were fouled and they were champion plugs, so today i put new ngk plugs . it runs ok but it still bogs down but idle good 950 rpm,   now heres the funny thing i do  have fuel in the tank, but   when i put the fuel valve on the on position and rev the engen i get the feeling its being fuel starved ,now when i turn the fuel valve to the reseve position the bike runs better but it has a little hestitation has anybody have any ideas or solutions  ???
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
Re: help help with a fuel problem or running
« Reply #1 on: July 29, 2005, 06:14:42 PM »
how full is the tank, mine will only run on 1-2 when I need to change over to reserve.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
750FSS
« Reply #2 on: July 29, 2005, 06:56:06 PM »
half full. ???
« Reply #3 on: July 29, 2005, 06:58:05 PM »
Do you have fuel contamination and/or enough fuel in the tank?
When was the last full and complete tuneup?
Air filter dirty?
Is the bike all stock?
eldar
« Reply #4 on: July 29, 2005, 07:09:38 PM »
Fouled plugs indicate a rich condition usually. You need to tune the carbs. Changing points and condensers, if it has been a while, would be good also.
750FSS
« Reply #5 on: July 29, 2005, 08:44:28 PM »
yes the carbs has been rebuild, new plus and point, i called the guy. he think that maybe the seal in the pet cock is bad. because the bike running on on reseve. i sound like the prolben the guy is with reseve  on cb750
http://www.sohc4.us/forums/index.php?topic=2969.0
eldar
« Reply #6 on: July 30, 2005, 10:26:03 AM »
Well it is hard to say. Get some small O.D. CLEAR tubing.  shut off your gas and pull the bowl drain screws out. put the tubing in the holes tightly. turn gas back on and see how high your level in the tubes gets. This will then indicate if the fuel level is too high.  The floats my be incorrectly adjusted. or the float valves may not be shutting off flow properly. I had this issue on 1 carb. moved the valve and the float shut off flow correctly.
Offline DrMark
« Reply #7 on: July 30, 2005, 10:55:23 AM »
Could it also be clogged jets?   Sounds like they may need a good cleaning...my 1978 CB550 did the same thing....
1978 CB550K
1983 CB650SC Nighthawk
eldar
« Reply #8 on: July 30, 2005, 12:54:56 PM »
If the jets are clogged as to not let in air, then yes it is possible.
750FSS
« Reply #9 on: July 31, 2005, 04:50:05 AM »
well today i full the tank up, and the bike is runnig good agian..
eldar
« Reply #10 on: July 31, 2005, 08:13:52 AM »
You may have to clean out your tank vents then. If your vents are clogged, as you use fuel, a vacuum is created and that prevents fuel from getting to the carbs. I dont see how this would cause build up on your plugs though. I would say that is a separate issue.
Offline 78_SaltLick
  • Honda 1974 550
    • Custom Drum making
« Reply #11 on: July 31, 2005, 08:44:13 AM »
i have a 750K8 with the same problem (bogging) i bought it couple weeks back, and the thing is on "reserve" with just a wee bit of gas in it. i filled it up yesterday, switched it to the "on" position, and it runs great now. I think theres some setiment on the bottom of my tank.
Gold sparkle is the place you outta be.
eldar
« Reply #12 on: July 31, 2005, 10:25:48 AM »
Could be you petcock needs to be cleaned or some work done on it.
750FSS
« Reply #13 on: July 31, 2005, 11:38:36 PM »
 i had the ckoe on which Fouled the plugs  :-[  now eldar your right about the petcock needs to be cleaned, i took it off and it had a lot setiment on the tube, clean it and the tank too .  will see how it go's... ???
« Last Edit: July 31, 2005, 11:40:53 PM by 750FSS »
