Author Topic: Morris Mag Help Neeeeeeeeeeeeded Sprocket?????????  (Read 1281 times)
Offline Gregorymoto
  • SOHC Aficionado
« on: January 13, 2008, 02:43:17 PM »
Ok hear is the short.
I have a set of Morris Mags, i can bolt up the 6 bolt pattern rotors (CB750 sohc) but i have know idea what the rear sprocket brand is. I have the sprocket that was on the rim when i got it, it is the same as the Cb rotor. I have tested and i'm not #$%*ting at least300 roters and have yet to find a match.
I know they used this Mag on KZ, CB, as well as HD XLCR, and XL sportsters i have ruled out HD, they use a 5 bolt pattern on every thing for the sprocket.
if you have a clue to a soultion i would love it.
Now the rims where bought from a guy that bought and parted out a twin motor CB750 drag bike. (ya it was cool)
I have had them for 9 years.
Just thought i wold throw this out and see if any one has info be for i build a floting rear sprocket bolt on.
Yep, i have issues with this sort of stuff.
Re: Morris Mag Help Neeeeeeeeeeeeded Sprocket?????????
« Reply #1 on: January 13, 2008, 03:11:29 PM »
Get a blank sprocket..drill to suit bolt pattern. Steel ones are available at power transmission type places.. aluminum..  order from a sprocket maker... you supply measurements.
Steel will be heavy and need center bored.
How wide is the rear?? is it 18 inch dia ?
Offline Gregorymoto
  • SOHC Aficionado
« Reply #2 on: January 14, 2008, 07:23:16 PM »
YA I found a place in Chico CA that will make me a new one.
Hoping someone out there might have a lead to help me figure out what i have.
Thanks for the info dident know you could buy blanks from a trans shop.
« Reply #3 on: January 14, 2008, 07:37:59 PM »
Not a tranny shop.. a bearings, belts, pulleys, sprockets, gear reductions type of place.. but they probably wont have aluminum.. nor will they be drilled..
Offline Gregorymoto
  • SOHC Aficionado
« Reply #4 on: January 14, 2008, 07:57:16 PM »
Drilling is no issue i have a milling machine. Thanks
Offline 736cc
« Reply #5 on: January 16, 2008, 04:19:34 PM »
sprocket specialists has sprockets for morris mag
