Author Topic: How hard to adapt 77 cb550 accel pump carbs to 76 cb550?  (Read 1202 times)
Offline L.A. Nomad........
  • 1976 CB550 K
« on: February 07, 2008, 10:28:17 AM »
Has anyone tried this? Is it worth the trouble? I've never ridden a later CB550 with accel pump carbs. What do you guys think?
L.A. Nomad
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
Re: How hard to adapt 77 cb550 accel pump carbs to 76 cb550?
« Reply #1 on: February 07, 2008, 10:42:18 AM »
None of the CB550 carbs have accelerator pumps.  The CB750 carbs do, though.
Offline SEBNN
« Reply #2 on: February 13, 2008, 10:53:49 PM »
From what I understand the accelerator pumps are only there as a work around for the EPA regulations back in the day.  I may be wrong, but carbs prior to then did fine without them, just had to run a little richer so that when you opened up the throttle it didn't get too lean during hard acceleration.
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #3 on: February 13, 2008, 11:00:12 PM »
'79-80 650 (pump) carbs should fit the 550 head. i haven't tried it myself, but i am fitting 750 carbs to my '79 650 head going on my 718cc project, and people have reportedly used 750 carbs on 550s, which would lead me to believe that the spacing of the three must be pretty close. i'll try and remember to compare some when i'm at my shop tomorrow.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
