Author Topic: Types and makes of replacment carburetors for the 750.  (Read 14362 times)
Offline Soos
« on: February 08, 2008, 06:46:24 PM »
http://forums.sohc4.net/index.php?topic=30624.0;topicseen
In this post there is a fuel injection system talked about, I know Cycle-X offers a dual carb setup, as well as the  DCOE Webber setup I have seen for sale on E-bay.
Does anyone know of any other setups that are either a drop in part?
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline mkramer1121
Re: Types and makes of replacment carburetors for the 750.
« Reply #1 on: February 08, 2008, 09:48:27 PM »
Kehin CR's (New, around $700), Mikuni Smoothbores (old, vintage, require carb boots, from $250~$500, plus $150 for the boots)...Mikuni also makes newTMR34's as well, but they are over $800
« Reply #2 on: February 09, 2008, 03:37:09 AM »
For my money, the CR's are about the best thing you can use on a 750. The Mikuni smoothbores are difficult to tune, as are the Webers and Dellorto's, not to mention that the DCOE carbs weigh a ton. Cheers, Terry. ;D
Offline mkramer1121
« Reply #3 on: February 09, 2008, 07:25:00 AM »
yeah, but CR's are sooo....UGLY
« Reply #4 on: February 09, 2008, 11:44:12 AM »
Terry , obviously you have never lifted a DCOE..I am thinking..
The jetting is very quick to change, but there are more circuits to deal with, meaning you can pretty well tailor any part of the throttle opening.plus you dont have to  pull them off to change stuff, can change you venturi sizes in 5 minutes, and they have ball-bearing throttle shafts..
« Reply #5 on: February 09, 2008, 02:28:59 PM »
Ha ha, I carried a set of Dellorto 40DHLA's, (which I understand were copies of the DCOE's) all the way to the Post Office when I sold mine on Ebay mate, they weighed in at around 10 pounds!
The CR's are a snap to change needles and jets on the bike, so I just couldn't see any point in keeping the DHLA's. Any "race" carbs that need a bracket to hold them to the frame, so they don't fall off the engine, is a little too heavy for my liking.
Sure, they look nice, but if they were any better than the CR's, the factory teams would have used them, rather than CR's or Mikuni Smoothbores, which seemed to be the racers choice back then. Cheers, Terry. ;D
« Reply #6 on: February 09, 2008, 02:44:46 PM »
I dont see a lot of imported stuff on Works bikes in the early 70,s....
Mikuni did make a dual throat that was a bit smaller physically that the other 2 brands.. may have been Mikuni-Solex.
Of course there sould be a  brace they go back a lot further and are not held up with the airbox.. not real hard to move stockers up and down with pods on them..
I know stock 750 carbs weigh about twice as much as modern ones though..
« Reply #7 on: February 09, 2008, 03:39:10 PM »
Yeah, quite right mate, the new CR's are very light indeed. If you use the DCOE's and a magneto, you'll be adding about 20 pounds to the weight of the bike. Cheers, Terry. ;D
Offline mkramer1121
« Reply #8 on: February 10, 2008, 09:41:49 AM »
Hey DG, how do you do a carb sync on the VM29's?
« Reply #9 on: February 10, 2008, 10:34:03 AM »
Terry, the carbs may weigh a few more lbs, but yours will probably never spin the tire w/o the clutch at  15 -20 mph!! ;D ;D
 Not sure what CR,s get for gas mileage, but the Webers are pretty good.
 I will weigh a set of stock carbs, they never felt very light to me..
« Reply #10 on: February 10, 2008, 12:04:43 PM »
Ha ha, you better come over and take it for a ride mate, it does that already! There's a lot more work in it than just CR carbs though, and I hope you're not saying that a set of DCOE's are gonna make that kind of difference to a stocker? Remember, they're carbs, not a supercharger, but if you're saying they will, maybe you should be posting here........ ;D
http://forums.sohc4.net/index.php?topic=15282.0
« Reply #11 on: February 10, 2008, 06:09:46 PM »
Well Terry , I have not seen any of the carbs anyone mentioned on here referred to as, "The Closest thing to Fuel Injection".. but that is a pretty common reference to the Webers.. However when I start hearing that I lot I will pay close attention..
Ask any Ford GT40 owner..
I did see the PO of my carbs dust off a Z1 pretty badly on a stock bore and cam CB750...
« Reply #12 on: February 10, 2008, 08:00:01 PM »
Yeah, I know mate, back in the day there were a lot of claims made about bolt on performance products like carbs and pipes, and considering that the stock carbs weren't all that good, I can understand why "they" raved about Webers and Dellorto's back then.
I had a bone stock Suzuki T250 "smoke generator" a few years ago that would kick asss off the line, and I beat a few guys on much bigger bikes too, but I think maybe they were asleep..............  ;D
« Reply #13 on: February 10, 2008, 10:58:23 PM »
Well, methinks you need a scale!!
2 dellorto dual throats w/o manifold =9 lbs
Stock pre 76 carbs w/0 rubbers = 8lbs
 Complete Magneto, less plugwires, including beltdrive pulles and adaptor to crank = 6lbs
 Stock pointplate with point condensers w/o advancer  but includes stock coils between 2 and 3 lbs
So maybe 7lbs more, but I save that much on my smaller battery.
 So I am surprised you can spin the tire with throttle only, yet other CR owners are saying they cant open the throttle hard at lower rpm..see the dyno run thread..
« Reply #14 on: February 11, 2008, 12:55:10 AM »
Ha ha, well if you go back to my original post, you'll remember that I was comparing the weight of those weber DCOE's to modern CR carbs mate, I don't have a set of Webers handy, and my CR's are on my bike, so I couldn't do a comparison, but I'm guessing they're around half that of the webers?
And being the honest feller I am, I just went out to my garage and weighed an ARD MK2 Magneto housing with no pulleys, but Morse Fairbanks magneto, and the weight according to my new digital scales was 5.2 KG, or 11.44 pounds? I'm sure the extra long copper cored plug leads would add maybe another pound?
But hey, I was prepared to believe that your bog stock Z1 killing CB750 with just a set of Webers would allow you to spin the back wheel at 15-20 MPH, so why wouldn't you be prepared to believe that my engine with the following specs wouldn't? Here we go:
836cc 12:1 Arias pistons,
Mike Rieck stage 3 head,
Megacycle 125/75 cam,
CR 29mm carbs,
K&N pod filters,
Dyna S ignition,
Dyna 3 Ohm coils,
NGK Iridium plugs,
4 into 1 race pipe,
RC rods,
APE studs,
M3 racing cam chain tensioner,
Tsubaki cam chain, etc etc.
I mean, it'd be disappointing if this engine couldn't spin the back wheel at low speeds? Still, if you say that a stocker with just those webers will do all that, then who am I to question your integrity? Have a good one mate, I eagerly await your reply! Cheers, Terry. ;D
Offline Jay B
« Reply #15 on: February 11, 2008, 04:49:56 AM »
Terry, How much hp are you putting out with that setup?
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
« Reply #16 on: February 11, 2008, 07:04:19 AM »
I was talking 2 different bikes
Before I had a chance to buy the carbs I saw the PO dust the Z1..he had dragbars, 17/54 gearing and  a header on a stock motor.. I was simply illustrating that they seemed to work on a stock engine.. I ran them on a few stock motors as well.
But my bike  would spin the tire  with a lighter rider at low speeds..it is an 10.5cr 836, with stock valves & crank, unported head and RC cam...running points.
The mag that I have not run yet, was what I weighed last night.
I have read several times on here  about the built motors not  starting to really work till in the upper rpms, and a lot of them are running CR's.... they are not talking gobs of power down low.
Offline mkramer1121
« Reply #17 on: February 11, 2008, 08:21:55 AM »
I think the issue is with how the motors were built, not the carbs themselves.  A number of people have built motors and gotten the wildest cam that they could.  Unfortunately, this doesn't always work for a streetable bike.  I'm pretty sure that cam profile, carb size, valve size, etc., all determines what RPM power comes on at.
« Reply #18 on: February 11, 2008, 12:25:56 PM »
G'Day Jay, no idea mate, Mike Kramer very generously gave me a crank which he sent to Big Jay at APE (and should be in the air by now thanks Mike) to lighten and balance, so the engine is about to come out again so I can install it, and then I'll try to find a good tuner to put it on his Dyno and see what comes out. I'm hoping to get around 80 BHP at the rear wheel, any more would be a real bonus! Cheers, Terry. ;D
Very true Mike, not having any tuning "gift" of my own worth a shiite, I relied heavily on Mike Rieck's advice so when he built the head, he built it with an 836cc kit, Megacycle 125/75 cam, and 29mm CR's in mind, and they work well together. The engine is very reliable, and pretty mild mannered around town, my biggest problem is that the K0 "restification" keeps dragging me away from it, I wish I was wealthy enough to retire so I could give all my bikes a little more attention, ha ha! Cheers, Terry. ;D
Offline mkramer1121
« Reply #19 on: February 11, 2008, 12:50:57 PM »
I was talking to an old racer a while ago, and he said too big of carbs can have a huge effect as well.  They'll come on later then smaller carbs.  He would use one size larger carbs at Daytona due to the amount of throttle you could grab there in the straights.
« Reply #20 on: February 11, 2008, 04:36:31 PM »
Yeah, it's an interesting thing Mike, Keihin infer in their booklet that the CR31's are more suitable to a bike over 750cc, but most of the posts I read from Sean and Art is that the 29's are actually running a little rich, and Sean has reduced his main jet size. The last thing I want to do is "over-carb" it.
I raised the needle two notches originally to richen the mixture, but it's a tad too rich now, so I'll drop the needle 1 notch and it should be about right for my purposes. When I build my 1060cc engine I'll probably go a set of 31's, I've got some Mikuni 34mm flat slide race carbs (which are lighter than the CR's) that I'd like to try, but I might not be able to get the spacing right. (they're for a GS Suzy engine)
I'm also tossing up about the CycleX single phase alternator? It's supposed to reduce the weight by a few pounds, albeit at the loss of the starter motor? That doesn't worry me as the kicker starts it fine, but has anyone tried one yet? Cheers, Terry.  ;D
« Reply #21 on: February 11, 2008, 08:10:16 PM »
I tried 32mm carb throats..  turned pretty well the same ET,s but harder to ride and  noticeably less bottom end..
Must suck to have to pull your carbs to go bigger on the venturis.  10 min job for some of us   ;D   ;D
I  never held a Honda ARD mag in my hand, so I did not know how much they weighed.. I did notice though the newer generation CDI type for Kawi is only 6.3 lbs... alway figured those wopuld be adaptable to a 750 Honda..
« Reply #22 on: February 11, 2008, 10:26:10 PM »
Have you ever actually changed the venturis "on the bike" mate? There's barely enough room in the gap betwixt carb and frame for the "pan cake" air filters, so best of luck getting the venturis (that span the width of the carb, of course) out. Of course, WHY you'd need to change venturis is a whole other question...............
I've got several ARD MK2 CDI magneto's for Z1's in my garage, I sold an ARD MK2 for a Honda to one of the guys here a year or two ago, they're a lot lighter than the MK1, but 30 year old CDI's don't inspire much confidence, (in fact I've got two that have been converted back to points, but they weight more again) they also need special external ARD coils, and you've got the problem that you'll have with most magnetos, you have to start it on full advance. Can you say "kick back"? Ha ha, Cheers, Terry. ;D
« Reply #23 on: February 11, 2008, 10:47:51 PM »
I changed venturis on the chopper without a problem, running out to look at my stock frame right now..
Looks like they will come out easy.. The first part is the bombsight, pull the screw & pull it out with 2 fingers.. them pull the Venturi.  As far as I know that is it, unless the venturi comes out the front (been a long time) them you would have to pull 2 bolts. Proper name is actually chokes. the 2 pieces are near the length of the carb but the longest is about 2 inches.
On the stock frame the clearance problem for aircleaner is at the top, the rest has lots of room with sidecovers off.. I been running without..had bugeyes on it but last time I went to use them the black foam was crumbling so I ran without..
Why would you want to change venturis?? same reason as you went to 29mm carbs or are thinking of going to 31mm on a bigger motor.
« Reply #24 on: February 12, 2008, 01:43:20 AM »
Yeah I guess, but the bigger engine is going into another bike, so I'll still need a second set of carbs, regardless. Cheers, Terry. ;D
