Author Topic: Can anyone identify this electrical bit  (Read 1525 times)
« on: March 05, 2008, 08:32:00 PM »
the box in the top right corner with the red plug
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: Can anyone identify this electrical bit
« Reply #1 on: March 05, 2008, 08:36:15 PM »
I'm guessing voltage regulator
 Matt.
Gallery at:
« Reply #2 on: March 05, 2008, 08:38:57 PM »
nope thats behind the fuse box, yuo can kinda see some of it in the pic
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #3 on: March 05, 2008, 08:41:42 PM »
RECTIFIER, SILICON?
I just went to here:
http://www.westernhillshondayamaha.com/fiche_section_detail.asp
and looked up a 75' 550F and got this fiche:
Gallery at:
« Reply #4 on: March 05, 2008, 08:47:27 PM »
thanks for that , matt
i have no clue what year this came off of , it's very close to what i had (exept for the mystery box)
fuzzybutt
« Reply #5 on: March 05, 2008, 08:49:36 PM »
red plug = starter safety relay
« Reply #6 on: March 05, 2008, 10:21:21 PM »
Yup its the box that wont let you use the electric start unless the neutral light is on OR the clutch lever pulled in
« Reply #7 on: March 06, 2008, 07:43:44 AM »
ok ... i have removed the plug from the clutch lever ..... so can i bypass this as well
actually .. now that i know what it is , i'll work it out..   thanx guys
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #8 on: March 06, 2008, 07:56:32 AM »
That the panel I sent you Spikey?
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
« Reply #9 on: March 06, 2008, 09:25:25 AM »
the one you sent was missing the regulator , so i found this one on ebay for next to nothing (I know shocking right ) for the parts.
i had never seen that red plug before , but i knew i wasnt going to use the whole thing so. . . .
thanks again to you and all others for the donations . i hate being a chairity case, but there is no way i could have done it with your guys help
