Author Topic: cb350f into cafe  (Read 3548 times)
Offline mireparo
cb350f into cafe
« on: March 10, 2008, 11:37:48 AM »
Well here's my current project until I run out of funds.
I bought cb350 form mikedialect a couple months ago.
Definitely in need of a little TLC. One of the cylinders got water in it and the valves were ruined. Found a head on ebay. Honed the cyclinders and I think they'll be fine.
I was inspired by everybody pounding knee dents in there tanks so I went to town and was pretty pleased with my results.
I bought a triple clamp and forks from a 750 to beef up the front and all used cb350f forks seem to be rusted up bad. Found a 2.15 rim for the rear and will use original 1.85 rear in the front.
My current problem is to mount the forks. The triples mount to the frame no problem with the addition of a small spacer, but the forks are 3" longer which is length I don't want. I want the tops of the forks to be flush with triples.
The solutions I've thought are either shorter tubes or the addition of a spacer which stop the tube from extending fully. For either option I would need to cut my spring to avoid excessive preload and i would lose travel and risk bottoming out. I think I'll try adding the spacer and only cut the springs minimally to add more preload (I am large and am shooting for looks more than function) and hope it doesn't bottom out.   Any suggestions????
erb4
Re: cb350f into cafe
« Reply #1 on: March 11, 2008, 01:37:39 PM »
Here's a thread off another board that may help you out.  Scroll thru the first few posts and look for one by a guy named "scraper."
http://www.jockeyjournal.com/forum/showthread.php?t=5317
Offline mireparo
« Reply #2 on: March 11, 2008, 08:43:06 PM »
Thanks erb!! I'm going to give that a shot.
Offline wardmoto
« Reply #3 on: March 18, 2008, 07:35:54 PM »
IT CAN BE DONE......
03 Suzuki SV 1000S
86 Suzuki GS 550ES
72 Honda CB 350K
72 Honda CB 350F
72 Honda Cb 350F cafe
Offline KB02
« Reply #4 on: March 19, 2008, 04:17:05 AM »
Cycle-X sells shorter fork tubes for the 750. You can check with them.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
