Author Topic: Honda CM400 valve seal question  (Read 2413 times)
Offline Johnie
« on: March 23, 2008, 07:01:07 AM »
I have a 1981 CM400 Custom I bought last summer with 1,300 miles on it and it obviously sat a lot.  It's a beautiful original bike that I put 1,500 miles on last summer.  The bike sat so much the valve seals are pretty dry and need replacing as it blows smoke on start up only after sitting.  The compression is good in both cylinders.  I was told I should be able to replace those valve seals by only removing the valve cover, cam, etc. and that I would not have to remove the head.  Does this sound do-able?
Thanks...
« Last Edit: March 23, 2008, 07:24:01 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline mark
Re: Honda CM400 valve seal question
« Reply #1 on: March 23, 2008, 07:23:14 AM »
If we were talking about an old Ford pickup, I'd say "yeah no problem go for it"...
I don't see it happening on the CM. I think the head needs to come off.
sorry
F you mark...... F you.
Offline Johnie
« Reply #2 on: March 23, 2008, 07:28:07 AM »
Yah, it was an old bike mechanic that mentioned it.  I was not sure and have never dug that far into an engine before.  I have gone into V-8's and done valve jobs, but nothing that deep in a bike.  I sort of wanted to see what is involved before I try it.  I have the service manual but wanted to hear from the board experts.
Thanks
Oshkosh, WI  USA
troppo
« Reply #3 on: March 23, 2008, 07:32:09 AM »
use the old string trick...................
remove the battery (makes it idiot proof) take of the rocker cover and the spark plugs, i dont know the particulars of the bikes but i have done this with a car, push a heap of string into the cylinder and turn he crank over, when you cant turn it over you have enough string in there, that will hold the valve in place while you replace the seals
cheers mate
troppo
Offline crazypj
  • I'm brill, me
« Reply #4 on: March 25, 2008, 11:02:00 AM »
In my experience the head has to come off (easy though as there are holes in the frame to allow for this)
 The cotters 'stick' to the valve after a long time just through normal spring pressure.
 Remove cam cover, back off rockers, undo the 8 long bolts on rocker/cam bearing mounts, (don't remember if there are 6 or 8mm bolts as well?) pull out tensioner blade and guide (not sure of exact sequence, haven't done one since around 1981~2)
PJ
