Author Topic: CB350 - which Carb rebuild kit?  (Read 3611 times)
Offline frappy
« on: March 31, 2008, 11:46:46 PM »
My '73 CB350F is going to need a carb rebuild as I've adjusted valves, replace plugs and points, but continue to foul plugs 3&4.
Y'all have any kit recommendations; K&L, Keyster, Sudco?
Also, should I plan to do all four carbs since they'll be off the bike?
Thanks!
CB350F
MT250
Offline Raul CB750K1
Re: CB350 - which Carb rebuild kit?
« Reply #1 on: April 01, 2008, 01:15:06 AM »
Why don't you go original? Honda still have them, and chances are they are cheaper than aftermarket.
Offline mark
« Reply #2 on: April 01, 2008, 01:55:27 AM »
+1
The OEM gasket kit often has more of what you need than the aftermarket sets. Unless you have an unusually high-mileage bike, the metal parts should be reusable. The jets and needles included in the aftermarket kits are reputed to be of questionable quality. You will not hear many members bragging about how they Keystered a set of carbs. :o (even sounds painful, doesn't it?)
I'd do all four and not wonder when 1&2 are going to start acting up - they all get the same fuel from the same tank.
Happy trails.
F you mark...... F you.
Offline cben750f0
« Reply #3 on: April 01, 2008, 03:06:21 AM »
keyster are ok if you dont use the air screws.... i did and they are made of brass, when i screwed them in the spring took shavings off the screw and clogged the carbs again!!!, use oem if you can superior quality.
peace
Offline Jay B
« Reply #4 on: April 01, 2008, 04:44:51 AM »
peace
I used Keysters also. Didn't have an issue with the air screws, but I thought the slide needles looked to have a slightly different profile than the old ones, so I cleaned them up and reused them.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline frappy
« Reply #5 on: April 01, 2008, 10:54:48 PM »
Thanks folks. I'll be looking to get the Honda complete kit for all 4 carbs. Bikes got 14k miles and it's time to get some fresh jets inside the carbs. Now if I can just muster up the wherewithall to dig into 'em :-\
CB350F
MT250
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #6 on: April 02, 2008, 11:05:39 AM »
I wasn't aware that Honda still had a "carb kit" for the 350F. If you find them Frappy I'd appreciate it if you can post the Honda part #.  8)
 Thanks, Matt.
Gallery at:
