Author Topic: Torque values for engine covers?  (Read 1711 times)
Offline scondon
  • Mmmm......tasty bugs
« on: August 12, 2005, 10:53:50 AM »
I've got my '78 motor all buttoned up and ready to install this weekend. While everything is still easily accessible, I'd like to know what Torque you guys are using on the valve cover, shifter cover, clutch cover, etc...  I've installed all the covers using 12 foot lbs. of torque and it "feels" about right but want to double check. I'm using stainless hex head(allen) bolts if that makes a difference.
Re: Torque values for engine covers?
« Reply #1 on: August 12, 2005, 11:46:32 AM »
12lbs  is a lot Sean. I'd say 5lbs to 6lbs. Make sure you use anti seize on those bolts!
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #2 on: August 12, 2005, 11:49:09 AM »
I found this page that has some of the specs listed.  Not sure that everything you need is there, but I found it helpful.
http://www.geocities.com/c_f_l@sbcglobal.net/spec.html
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
Offline scondon
« Reply #3 on: August 12, 2005, 12:00:09 PM »
Thanks guys. Do you think I should back off the torque, or will the gaskets sealing properties be compromised by my "heavy handedness? I actually set everything at 8ft. lbs before going to 11.5 'cause it seemed so loose, DOH! Not even a 1/8 spin of the bolt between these two settings so I'm almost inclined to leave it unless this might actually cause leaks or thread failure. Thoughts?
