Poll
how much antisieze do you use
I use a bunch on every thing
1 (3%)
I use a touch on every thing
4 (12.1%)
I use some on most bolts
12 (36.4%)
I use anti-sieze on bolts I know I'll have to remove again
13 (39.4%)
I don't use anti-sieze at all
1 (3%)
What's anti-sieze
2 (6.1%)
Total Members Voted: 31
Author Topic: anti-sieze  (Read 1607 times)
76 cb550
anti-sieze
« on: April 16, 2008, 12:45:50 PM »
1. do I need to apply more torque to a bolt that is suppose to be applied dry if I put anti-sieze on it.
2. Are bolts more likely to work themselves out of the case if they have anti-sieze on them
3. I have aluminum anti-sieze...should I have copper instead
4. Is there anything I should NOT use anti-sieze on (I'm sure there is...stupid question in hindsight)
5. the haynes manual says that I need to apply locktite to a bolt (damper fixing socket socket cap screw: clymers calls it the piston rod thread...while I'm reassembling the front forks on my cb550k...anyone know which bolt this is and is the loctite really necessary?  I think they are talking about the allen bolt in the bottom but I stripped that thing getting it out in the first place...I'd hate to put loctite on it without being sure I need to.
« Last Edit: April 16, 2008, 01:16:14 PM by 76 cb550 »
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Re: anti-sieze
« Reply #1 on: April 16, 2008, 12:54:58 PM »
I use 'Never Seize' on any bolts which are likely to suffer from the ravages of moisture. Also on stainless bolts going in to alloy.....apparently this is a good thing. Anyone?
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
76 cb550
Re: anti-sieze
« Reply #2 on: April 16, 2008, 12:59:13 PM »
It's my understanding that it is specifically used for dissimilair metals touching.  The different metals fuse through electrolysis.  The anti-sieze prevents this so yes I'm pretty sure it's good to use antisieze when putting a steel bolt into an alloy (non-steel metal)
Re: anti-sieze
« Reply #3 on: April 16, 2008, 01:26:18 PM »
This is what would be called a wet torque, so you would up the torque by 10%. However if the bolt has been torqued already so it has been stretched. I would use the dry torque.
2. Are bolts more likely to work themselves out of the case if they have anti-sieze on them.
No, it insulates the two metal surfaces from each other. It also hardens a bit and fills the voids in the threads a bit.
Copper is really for high heat use.
Well you would not use low temp anti sieze on exhaust flange bolts due to the heat.
I am not certain which bolt they are referring to. In most cases the milder Loctites are fine. This product also insulates the two metals.
76 cb550
Re: anti-sieze
« Reply #4 on: April 16, 2008, 01:30:29 PM »
so the (mild) loctite could actually make it easier to remove this bolt again in 30 years by preventing electrolysis=).  That's priceless.
Offline KB02
Re: anti-sieze
« Reply #5 on: April 17, 2008, 04:57:19 AM »
I use Never Seize, especially when working on exhaust stuff. Those bolts really tend to rust solid and the never seize really helps.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Re: anti-sieze
« Reply #6 on: April 17, 2008, 05:11:40 AM »
 I use the copper never seize on stainless fastners going into aluminum.
Offline ieism
Re: anti-sieze
« Reply #7 on: June 11, 2008, 05:08:44 PM »
I'm having a little trouble finding this stuff here.....Is copper "never seize" something completely different from normal copper grease?
---cb550---
Re: anti-sieze
« Reply #8 on: June 11, 2008, 07:34:27 PM »
No...it is "copaslip" (or something like that) in Europe
Offline medic09
Re: anti-sieze
« Reply #9 on: June 11, 2008, 09:44:18 PM »
I put just a little on the spark plug threads.  They go in easy and come out easy.  No hassles.
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
Re: anti-sieze
« Reply #10 on: June 11, 2008, 10:44:05 PM »
what he said!  ;D  saved me MUCHO hassle over the years - especially on the old air-cooled VWs plugs and exhaust studs / nuts.
Now, if they would only come out with an "anti-SLEAZE" compound, I would buy a 5 gallon bucket of it and coat a few of the ornery critters that live around around here (the neighborhood homeless bums, and a couple of local old guys that hit on me WAY too often and without class.  ..lol)    ::)
« Last Edit: June 12, 2008, 03:49:54 AM by MoTo-BunnY »
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
Offline crazypj
  • I'm brill, me
Re: anti-sieze
« Reply #11 on: June 11, 2008, 11:03:37 PM »
Less torque as bolt is spinning easier
 not if they are torqued correctly
How hot is it getting?
not a good idea on brake pads, rotors or drums/shoes  ;D
 I never re-loctite them.
you mean you rounded it out, if its stripped you need a new damper rod
PJ
Offline hymodyne
Re: anti-sieze
« Reply #12 on: June 12, 2008, 03:23:31 AM »
+1
hym
