Author Topic: Wiring...  (Read 606 times)
Offline JLeather
Wiring...
« on: May 17, 2008, 06:56:48 PM »
So, I removed my headlight bucket for painting, along with the headlight ears and gauges, etc.  Getting the headlight off was a major PITA 'cause I had to pull all the connections to get the wires out of the headlight.  There was very little slack, and everything was wrapped and tangled and all.  It's a late '70 K1, BTW.  How do I put it back together?  Is there a trick or something?  Or do I just have to go wire-by-wire with my hands crammed into the headlight trying to find all the connections?
tbone
Re: Wiring...
« Reply #1 on: May 17, 2008, 07:00:15 PM »
A couple pairs of long needle nose pliers really help you see where you're doing.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Wiring...
« Reply #2 on: May 18, 2008, 06:10:18 AM »
Pretty much wire-by-wire. Fortunately, Honda did a good job with the color coding (assuming this is a stock harness). Take them one at a time and match the colors. Not sure if the K1 harness is different, but on the K0 I found I had one unused female (brown I think) connector left. Must have been used in some other application, because everything worked fine.
Offline Johnie
Re: Wiring...
« Reply #3 on: May 18, 2008, 06:17:30 AM »
Bob is correct.  There is a brown female not used in there.  I just put my bucket back together after paint 2 weeks ago.  It really went together problem free.  I did have to use a test light to get the blinker wire ends back in the right spot.  I also used a hair dryer to help bend that heavy wire protection in the angle I wanted.  Good luck with it.  I think you will be fine...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Online bryanj
Re: Wiring...
« Reply #4 on: May 19, 2008, 07:15:21 AM »
Brown wire is for markets like UK where ther is a 3watt running light (same bulb as idiot lights) in a seperate fitting in the headlamp reflector, which were replaceable bulb type and never sealed beam by the way
Offline DJ_AX
Re: Wiring...
« Reply #5 on: May 19, 2008, 08:08:50 AM »
PO had mine all cattywompus. A handful of different colored wires twisted in.. I numbered them before disconnecting. I'll re-wire next winter. 8) for now I'll ride  ;D
