Author Topic: did any Cb750's come with an 18" front wheel?  (Read 4599 times)
Offline pampadori
  • slingshotcycles.com
    • Slingshot Cycles
« on: May 20, 2008, 05:37:08 AM »
i was told this wheel was off a cb750.  its front rotor is the same size as my other cb750's. but it is an 18".  Is this wheel off a automatic maybe?
Shaun
www.slingshotcycles.com
brake hoses and more!
SOHC4 is your coupon code for 15% off!
Offline tortelvis
Re: did any Cb750's come with an 18" front wheel?
« Reply #1 on: May 20, 2008, 08:00:48 AM »
According to the fiche for a 1976 CB750k there is both a 19" and an 18" on offer.
Offline Geeto67
  • A grumpy
« Reply #2 on: May 20, 2008, 08:05:52 AM »
not an auto wheel - auto wheels are alloy, that sucker is steel.
Despite what the fiche says, I have never seen an 18" front wheel on a cb750 that was stock. It is certainly possible but I can;t imagine that is common.
Maintenance Matters Most
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: May 20, 2008, 08:20:35 AM »
Looks like it will work - the only issue would be the speedo drive.  If it's built for a 19" wheel, it will be off by a bit.
Anyone can lace a different sized rim to the hub - people put 16" Harley rims on the rears all the time.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline pampadori
    • Slingshot Cycles
« Reply #4 on: May 20, 2008, 08:40:46 AM »
it was a d.i.d. wheel. pretty sure it was factory.  i wonder if it was a later model of something.  did the 69 also have 19 inch?
Offline Klark Kent
« Reply #5 on: May 20, 2008, 08:43:58 AM »
yup thats it. definitely a sandcast wheel.   ;D
what are the effects of smaller front wheel?- is the difference between 18 and 19 enough that it was offered as an option to pick one or the other?
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Offline Roach Carver
« Reply #6 on: May 20, 2008, 08:47:37 AM »
69 was a 19.
Offline pampadori
    • Slingshot Cycles
« Reply #7 on: May 20, 2008, 08:56:18 AM »
Maybe someone will chime in with some truth to the myth that 18" was an option.  maybe the prototype had a 18", or maybe the CR?   ;)
« Reply #8 on: May 20, 2008, 09:11:39 AM »
None of the 500/550s or 750s came with an 18" front. The 400F did. That's a rim someone laced later.
I use an 18' on the front of a 550. It quickens the steering somewhat but requires a speedo drive from a 400 for the speedo to read correctly.
Offline jeanhank
  • streets & roads
« Reply #9 on: May 20, 2008, 11:09:29 AM »
That's right, the automatics had 19" aluminum wheels, same as the 75-76 GL1000.  Quite nice, actually, looks like a Borrani.
A smaller front wheel allows for quicker turn-in.  A lot of the European bikes from the 70s had 18 inch front wheels... It would actually make a great wheel for a cafe racer, which, after all, was a Euro thing originally.
erb4
« Reply #10 on: May 21, 2008, 11:01:16 AM »
CB200's came with a 18 x 1.65 rim.
Offline Klark Kent
« Reply #11 on: May 21, 2008, 08:24:50 PM »
thats huge! like an adult bigwheel?  how does THAT effect handling!?
got to admire your fearless flaunting of motorcycle standards running an 18 foot front wheel.
-KK
75 CB550k
95 KLR650
you'll feel better.
