Author Topic: SHould I be able to rotate crankshaft counter-clockwise?  (Read 3721 times)
Offline neudl
« on: May 27, 2008, 09:38:05 PM »
WHen I reassembled the top end, the crankshaft would not turn.  After pulling everything apart, it turns out the camchain was caught up on something.  I now have the head back on, and the crankshaft turns clockwise, but not counterclockwise.  I can't recall whether it would rotate counterclockwise before.  Anyone know?
Offline markjenn
  • CB750K1, CBX, RC30
    • Whizmo and Gizmo
Re: SHould I be able to rotate crankshaft counter-clockwise?
« Reply #1 on: May 27, 2008, 10:17:08 PM »
I've heard some folks recommend avoiding rotating the engine backwards, but I've never heard of one that can't be rotated backwards.  If it's physically obstructed from turning backwards, that sounds like a problem.  Is it making any strange noises when you rotate it forward?
- Mark
Offline crazypj
  • I'm brill, me
« Reply #2 on: May 27, 2008, 10:55:55 PM »
It should turn but will be much harder than turning in 'normal' direction as the starter motor (including all the reduction gears) will be engaged and have a high torque. its not recommended as cam chain tensioner could get damaged.
 I've seen a situation where the chain wasn't tensioned properly and turning engine backward made it jump a tooth or two  (then it bent a bunch of valves when guy hit starter button)
PJ
Offline Raul CB750K1
« Reply #3 on: May 28, 2008, 12:28:07 AM »
PJ
The chain must be VERY loose to have a tooth jumped out of place
Offline crazypj
  • I'm brill, me
« Reply #4 on: May 28, 2008, 12:31:18 AM »
Turning it backwards compresses tensioner blade
Offline neudl
« Reply #5 on: May 28, 2008, 06:30:46 AM »
So with the tensioner in I should not expect it to turn counter-clockwise? ???  I want to make sure that if there is a problem that necessitates me pulling the head back off, I do it now instead of after I have the valve cover and carbs back on.
Offline lordmoonpie
    • Moonpie
« Reply #6 on: May 29, 2008, 04:01:45 PM »
It should turn both ways no problem although backwards will compress the tensioner more so may be slightly more resistance tan forwards. It will go though so it sounds liek you've got somthing really wron inside. I had a similar problm recently on my CB450 - traced it to a shim on the CR gearbox. If I remove the shim it works fine, leave it in and it locks the crank.
You could have one of many problems but it's definitely a problem...get it apart now!
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline neudl
« Reply #7 on: May 29, 2008, 04:09:23 PM »
Thanks - It's back apart.  I think the problem is a bent tensioner
