SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Stud Insertion Tool
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Stud Insertion Tool (Read 2629 times)
SD750F
Master
Stud Insertion Tool
on:
July 10, 2008, 09:19:15 AM »
I scanned the internet for a couple days now and could not find any 8mm head stud insertion tool. So I decided to make a couple for myself. Pretty easy using a metric internally threaded couple and a metric set with a ball tip. I attached McMaster-Carr's part number/drawings for easy purchase on
www.mcmaster.com
What I am going to do is insert the set in one end of the couple. Thread the couple and set onto the end of my new stud. Torque it down to specification. Remove the torque wrench and release the couple by backing out the ball end set. Presto, should work like the 10mm stud insert tools I have seen.
Scott
Logged
martino1972
Guest
Re: Stud Insertion Tool
Reply #1 on:
July 10, 2008, 10:18:28 AM »
i always take 2 nut's with a washer in between,and tighten the nut's together on the stud,then it funtions as a bolt head,insert the stud,and remove the nut's...done..
Logged
mystic_1
Really Old Timer ...
1970 CB750K
Reply #2 on:
July 10, 2008, 10:24:32 AM »
Good info and good idea, thanks!
mystic_1
Logged
- John Augustus Shedd
My build thread:
http://forums.sohc4.net/index.php?topic=68952.0
SD750F
Master
Reply #3 on:
July 10, 2008, 11:36:09 AM »
martino1972,
To make it easy to remove, you should reduce the amount of surface area opposing the force. So you have the primary threads of the collar with a very small area in opposition unlike two nuts where the force in opposition is equal to the driving surface.
Makes the process easier without the possibility of backing out your stub after you just torque in it...
Scott
Last Edit: July 10, 2008, 11:48:54 AM by SD750F
Logged
mystic_1
1970 CB750K
Reply #4 on:
July 10, 2008, 01:49:53 PM »
You should make up kits and sell them at a small profit
mystic_1
Logged
My build thread:
turboguzzi
Old Timer
Reply #5 on:
July 10, 2008, 03:12:18 PM »
+1 for martino's solution
who are mcmaster anyway?
TG
Logged
754
Reply #6 on:
July 10, 2008, 07:36:14 PM »
Mc MaSTER- cARR IS A HUGE INDUSTRIAL SUPPLIER IN THE us..
WE CAN GET STUFF FASTER FROM THEM TO CANADA, THAN SOME cANADIAN SUPPLIERS CAN..
Logged
Kelowna B.C. Canada
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
Stud Insertion Tool
