Author Topic: OIL  (Read 9661 times)
Offline scott_cb650
OIL
« on: July 23, 2008, 09:56:37 AM »
OIL
Why worry about tomorrow for tomorrow has enough troubles of it's own.
Offline Gordon
  • 750K1, 550K2
Re: OIL
« Reply #1 on: July 23, 2008, 10:04:58 AM »
Cheng Shin
upperlake04
Re: OIL
« Reply #2 on: July 23, 2008, 10:08:27 AM »
 You're both wrong
martino1972
Re: OIL
« Reply #3 on: July 23, 2008, 10:10:59 AM »
conventional or synthethic tires..???
Offline UnCrash
  • Pass
    • My Blog
Re: OIL
« Reply #4 on: July 23, 2008, 10:16:14 AM »
I use low viscosity fresh kill whale blubber to oil my 9mm automatic.  I recently switched from DOT 5...
fixahonda
Re: OIL
« Reply #5 on: July 23, 2008, 10:18:27 AM »
LOUD PIPES. I heard they save lives.
Thoughts/comments?
martino1972
Re: OIL
« Reply #6 on: July 23, 2008, 10:19:26 AM »
my rear wheel don't fit between the front forks,is this bad???
JimJ
Re: OIL
« Reply #7 on: July 23, 2008, 10:24:58 AM »
I literally LOL'ed... ;D
And just for good measure...
Offline .RJ
  • homebase in your airspace
Re: OIL
« Reply #8 on: July 23, 2008, 10:27:57 AM »
My bikes run on baby seal pelts
martino1972
Re: OIL
« Reply #9 on: July 23, 2008, 10:43:46 AM »
i took my pistons out to safe weight,but now she won't start..
what am i doing wrong???
Offline MJL
  • Don't listen to me, I'm no
Re: OIL
« Reply #10 on: July 23, 2008, 10:48:22 AM »
martino1972
Re: OIL
« Reply #11 on: July 23, 2008, 10:54:13 AM »
i have a 1973 cb750.........where do i check my coolant level???
Offline rbmgf7
  • 2>4
Re: OIL
« Reply #12 on: July 23, 2008, 10:55:37 AM »
it's next to the turn signal fluid reservoir
martino1972
Re: OIL
« Reply #13 on: July 23, 2008, 11:00:17 AM »
good thing you bring that up....my turn signal fluid is low,could that cause my handlebar misfire..???
Offline ColinMc
  • There aint no pickle like a super pickle...
Re: OIL
« Reply #14 on: July 23, 2008, 11:03:43 AM »
Call any autoparts store and ask for a waterpump for an old beetle...good times! They'll check the computer forever and then tell you to try the dealer lol.
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
Offline Roach Carver
Re: OIL
« Reply #15 on: July 23, 2008, 11:10:24 AM »
ask for a flux capacitor for a delorean.
Offline vames
Re: OIL
« Reply #16 on: July 23, 2008, 11:20:19 AM »
Hi Guys
My bike runs and drives beautifully. What's wrong with it and how can I fix it?
Offline ColinMc
Re: OIL
« Reply #17 on: July 23, 2008, 11:27:48 AM »
your tire pressures are low, and your throttle cable is routed wrong. Oh and don't forget to replace your clutch lever.
Offline UnCrash
  • Pass
    • My Blog
Re: OIL
« Reply #18 on: July 23, 2008, 11:38:15 AM »
Baked or fried?
Offline bunghole
Re: OIL
« Reply #19 on: July 23, 2008, 11:46:40 AM »
I noticed that the gas tank under the seat is awfully small.  What are you guys using?
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
fixahonda
Re: OIL
« Reply #20 on: July 23, 2008, 11:48:32 AM »
On that note, where is my reserve tank? I looked all over and only see the one on top. I started filling a beer can up with gas and using that as the reserve.
Offline UnCrash
  • Pass
    • My Blog
Re: OIL
« Reply #21 on: July 23, 2008, 11:50:11 AM »
Yamaha carb cleaner or Simple Green?
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
Re: OIL
« Reply #22 on: July 23, 2008, 11:53:12 AM »
Does not changing your oil regularly produce "Trans fat"  and doesn't that clog your bike's pipes?
Offline freezingprocess
  • Chris
    • My '76 CB550 Project Gallery Site
Re: OIL
« Reply #23 on: July 23, 2008, 11:54:23 AM »
Coca Cola.
'76 CB550k
Offline bunghole
Re: OIL
« Reply #24 on: July 23, 2008, 11:58:21 AM »
When I twist the thingie on the right side of the handlebars, the bike makes a loud noise.  Is that normal?
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
