Author Topic: Oil leak  (Read 1028 times)
Offline WFO
  • Will work for powerbands
Oil leak
« on: August 06, 2008, 02:33:04 PM »
Ok it's a 1982 cb 650 sc nighthawk 14k i have located a leak (not bad) but i intend on fixing it this winter, here is the blown up and # 6 is the bad gasket. My question is while i have this much of the head off what else can i inspect or replace what are possiable problem areas. I don't see any other gaskets that need replacing based on the blowup the valve cover gaskets should be fine is there any pucks or rings iam not seeing?
http://www.ehlerdingmotorsports.com/fiche_image_popup.asp?fveh=2957&section=123754&year=1982&make=Honda&category=Motorcycles&dc=289&name=CYLINDER+HEAD+COVER
82 cb650 sc nighthawk - 78 kz 650 b
Offline tonycb650
Re: Oil leak
« Reply #1 on: August 06, 2008, 05:58:14 PM »
Yes. there are two o-rings that you should replace. If you can find the parts fiche for the cylinder, you will see the o-rings fit between the cylinder and the head.
80cb650c 80 cm400
Re: Oil leak
« Reply #2 on: August 06, 2008, 10:13:38 PM »
You wont touch those other O rings unless you remove the head which you dont appear to be planning on. That "gasket" is in fact an O ring just not a round one
martino1972
Re: Oil leak
« Reply #3 on: August 06, 2008, 10:17:34 PM »
well,when you got that removed,you can take a good look at your valvetrain,like cam,rockers,timing chain etc..
the biggest problem these 650's have is one step lower,between the head and the cylinders...they really like to leak out oil from the sides,due to the o ring failure what tonycb650 was talking about..
all depence how far you wanne take this.....
