Author Topic: Carb Cleaning Question  (Read 882 times)
Offline ZanVooden
  • I don't need no stinkin' title
  • This was suppose to be a quick one month job...
« on: August 06, 2008, 06:29:03 PM »
Alright so I have one carb completely apart, and before I go dipping the thing in cleaner, i have a question.
Do I need to removed a bushing/seal that is sit in the carb body itself, and goes around the choke shaft? Will carb dip eat this, it appears to be fibrous.
Im saving as much as possible because that seems to be the general consensus around here, to not waste the money on the keyster kits, or other kits.
Any comments?
Dave
Offline tonycb650
Re: Carb Cleaning Question
« Reply #1 on: August 06, 2008, 06:53:04 PM »
If its not metal ,and is removable, I would just to be safe.
80cb650c 80 cm400
Offline Johnie
« Reply #2 on: August 06, 2008, 07:00:29 PM »
Yes, if it is plastic or something like plastic you should remove it.  There is a chance the harsh cleaner will remove it for you.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
