Author Topic: Diagnose these plugs....  (Read 996 times)
Offline timdhawk
  • 1978 CB750K
« on: August 14, 2008, 06:58:19 AM »
i have pods and a 4-1 exhaust from an F model.
These are the plugs before my carb rebuild. Bike ran rough, but ran....
These are the new plugs after trying to get bike to stay running (it still won't)
In deeper than I should be...
eldar
Re: Diagnose these plugs....
« Reply #1 on: August 14, 2008, 07:31:25 AM »
Which F model do you have? If it is the 77/78 then the white plugs are probably SLIGHTLY lean but the other plugs are going to be rich. If it is the 75/76 then the white plugs are certainly too lean and the others are only slightly rich.
What throttle position are these readings from?
Offline timdhawk
  • 1978 CB750K
« Reply #2 on: August 14, 2008, 01:56:11 PM »
i have a 78k (with F carbs apparently) The first set is from when i got the bike. it ran and rode but roughly. lots of hesitation on throttle and a lot of blipping the throttle to get it where it needed to be.
the second set are from my trying to get the bike to stay running after the carb rebuild. full choke and almost always full throttle to even get it to run for 30-45 seconds. any lowering of the choke at all and it died.
Offline scunny
  • don't call me expert
« Reply #3 on: August 14, 2008, 02:02:46 PM »
those 2 plugs on the right look as tho they are passengers, are you getting fuel to those ?
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
eldar
« Reply #4 on: August 14, 2008, 03:50:31 PM »
Probably needs the standard full carb clean including pulling out the slow jets and cleaning them with a copper strand.
The left side plugs are too rich, the right side are too lean.
Offline eurban
« Reply #5 on: August 14, 2008, 04:07:26 PM »
The plugs with color do indicate rich conditions but that would be expected with a prolonged attempt to keep the bike running on two cylinders with choke applied.  Problems for sure with the clean two; likely carb issue rather than ignition since they are not a 1-4 or 2-3 pair.  Check for fuel in the carb bowls and if ok proceed with a proper idle circuit cleaning . . .
« Last Edit: August 14, 2008, 04:13:09 PM by eurban »
