Author Topic: Tank emblem removal?  (Read 1763 times)
jollyroger
« on: September 13, 2008, 10:18:39 AM »
I need to remove the metal tank emblems for my CB500. How do they come off?
I would have put this message in the "tanks and petcocks" section but do not have a "Post New Topic" button there?
Thanx Much!
Jolly Roger
Offline Johnie
Re: Tank emblem removal?
« Reply #1 on: September 13, 2008, 11:06:54 AM »
Are you repainting the tank?  If so, you can be a little more rough on it.  I know there is a thread on this in FAQ as I used it for mine.  I used some dental floss and slide it under the emblem and did both sides a little at a time.  Once it was up a ways I used a flat knife and it came up fine.  I was even able to use the press nuts to put it back on.  Mine was on a CB750KO so I am not sure what set up you have there.  Good luck with it...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline toycollector10
« Reply #2 on: September 14, 2008, 12:28:32 PM »
Slip some dental tape in behind and gently apply pulling pressure etc....
1969  CB 750 K0
1973  CB175
1973  Z1 Kawasaki
jollyroger
Tank decals removal?
« Reply #3 on: September 18, 2008, 06:49:05 AM »
Now I need to remove the original tank decals that someone has painted over. Those things are on there good! Any ideas? ???
Thanx to all of you have sent answers to my questions. I need the help. :-\
Jolly Roger
