Author Topic: Adjusting carbs questions  (Read 1563 times)
Offline stay youth
« on: October 25, 2008, 07:38:31 PM »
I'm in the process of adjusting my carbs and I'm unsure how to adjust these? The air intakes? Mine seem to have different openings . 1976 cb400/4
thanks!
« Last Edit: October 25, 2008, 07:52:14 PM by stay youth »
1976 cb400f
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: Adjusting carbs questions
« Reply #1 on: October 25, 2008, 08:01:35 PM »
If you are talking about the choke plates, the ones seen in the carb bodies in the pics....
There are screws between each of the carbs on the linkages which adjust the plates individually. They should all be positioned about the same.
There is also an adjustment on the #1 carb which adjusts the whole works.
 Matt.
Gallery at:
Offline stay youth
« Reply #2 on: October 25, 2008, 08:18:43 PM »
thanks for the reply, i'm actually referring the the circular air intakes coming from the pods. when the choke opens and closes these open and closes, how do i adjust them and at what distance?
thanks
1976 cb400f
Offline Johnny5
    • CB350F build thread
« Reply #3 on: October 25, 2008, 08:29:57 PM »
thanks
Matt is right, that's the choke butterflies. They should all flip open and close the same amount.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline stay youth
« Reply #4 on: October 25, 2008, 08:48:18 PM »
Ohh ok my bad, is there a specified gap they can be adjusted too?
thanks again
1976 cb400f
Offline Johnny5
« Reply #5 on: October 25, 2008, 08:54:11 PM »
There's not much adjustment to them. Move the choke lever to close, it should shut all the little doors or whatever you want to call them. Move the choke lever to open and they should all be open all the way. That's about all there is. Someone else will chime in if Im wrong or not explaining everything.
1971 CB350
1973 CB350F
Offline stay youth
« Reply #6 on: October 25, 2008, 09:01:51 PM »
The problem with mine is that when i close them the gap varies on each intake, does this make sense? It would seem that they should all be the same but i'm unsure of what the correct gap is?
thanks again
1976 cb400f
Offline Johnny5
« Reply #7 on: October 25, 2008, 09:03:42 PM »
If it's minimal, I dont think it'll hurt much. The choke is only used when warming the bike up. The more important part is having the butterflies all open the same amount.
1971 CB350
1973 CB350F
KingCustomCycles.com
« Reply #8 on: October 26, 2008, 02:39:37 AM »
Linkage rods are adjustable and each one should open and close the same amount.
Offline stay youth
« Reply #9 on: October 26, 2008, 11:49:00 AM »
Great thanks so much for the feedback
1976 cb400f
