Author Topic: Gauge Faces - Does much light come through them?  (Read 1244 times)
Offline Really?
« on: November 24, 2008, 08:38:04 AM »
I am curious, after the gauge faces are stuck, does much light come through from the backside?  Is it a loss of functionality versus gaining looks?
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline kent400
Re: Gauge Faces - Does much light come through them?
« Reply #1 on: November 24, 2008, 09:48:46 AM »
Only a small amount of the light comes through the gauge faces. If you look at the bases where the bulbs fit you will see most of the light is directed around the sides of the inner body and emerges between the inner, and outer bodies at the top. Effectively illuminating the top of the dial. Some may well come through dial face so you could clean off the old lettering. The fact that you will be reassembling with the glasses clean inside will make a big difference to the illumination.
