Author Topic: Tool for plugs on wiring harness,?  (Read 952 times)
« on: December 15, 2008, 04:17:16 PM »
I have a few 77 or 78 F harnesses, that were on bikes outside with no sidecovers, tank or seat. The plugs got real hard and crack easily.
If you can switch to your old ones or others, they would be good harness to use.
Anyone change these?
Offline mystic_1
  • 1970 CB750K
Re: Tool for plugs on wiring harness,?
« Reply #1 on: December 15, 2008, 04:50:08 PM »
Each pin is held into the connector by a small metal barb that sticks out of the side of the pin.  They make a special tool that depresses this barb and allows the pins to slide out.
VintageConnections.com carries them:
mystic_1
Edit, they also carry the connectors, pins, and crimping tools, naturally :)
- John Augustus Shedd
« Reply #2 on: December 15, 2008, 07:48:53 PM »
A jeweler's-size screwdriver will also extract the blades and sockets.
Offline stresssolutions
  • 4 years on a motorcycle, Time Flies!
  • 03 RoadStar, I miss my Honda
    • bloggy thoughts
« Reply #3 on: February 25, 2009, 08:24:19 AM »
I made mine out of finish nails.  hammer and grind them into shape, use a short stick as a handle.
« Last Edit: March 08, 2009, 05:43:58 PM by stresssolutions »
Enjoying life, one day at a time.
