Author Topic: WTF was Honda thinking??  (Read 2400 times)
« on: December 24, 2008, 05:42:56 PM »
Once in a while I have to wonder why they do things.
 Like on 77/78 750,s they near doubled the thickness of the clutch  outer inspection cover.. Now the only reason I could see is it might decrease noise??
Of not, it is just a waste of steel on a bike that was already heavier than previous years.. I mean strong enough to weld footpegs to, I dont get it. ???
Re: WTF was Honda thinking??
« Reply #1 on: December 24, 2008, 06:09:12 PM »
Chill out Frank, it's Christmas ;D ;D ;D ;D ;D ;D ;D
All the best mate ;)
Sam. ;)
Offline Hush
« Reply #2 on: December 24, 2008, 11:07:14 PM »
Probably decided to do that at the same meeting some idiot suggested "why not leave the CB650 without a kick starter"?
Offline voxonda
« Reply #3 on: December 25, 2008, 02:20:31 AM »
Hey 754,
Yeah relax it's X-mas, concerning the cover I suspect because of the use of heavier clutchsprings. If you feel at a cover of a bike you can feel, some, movement of the case.
Heppy days and all the best, Rob
« Reply #4 on: December 25, 2008, 09:02:28 AM »
Vox, I am talking the chrome outer cover that comes off to attach clutch cable, and adjust freeplay.. not affected by the springs.. the one folks like to replace with a finned one.
Offline voxonda
« Reply #5 on: December 25, 2008, 09:05:37 AM »
OK, misjudged that one!
« Reply #6 on: December 25, 2008, 10:17:55 AM »
Maybe noise as requirements were starting to tighten? The cam covers are thicker and heavier as well. Maybe just a different vendor?
« Reply #7 on: December 25, 2008, 10:26:51 AM »
I am thinking of using them three mounts to hold a billet bracket with a hydraulic clutch unit, then boring through the main cover and using an o-ring to seal it. If that doesnt work may have to build whole cover.
Did some work on a Nascar style clutch release for a Cobra with a side-oiler. Was thinking if the hydraulic clutch unit has threads on the outside of it you could turn it in or out to adjust freeplay, then lock in place.. am thinking going hydraulic will  create a freplay problem?
Offline crazypj
  • I'm brill, me
« Reply #8 on: December 25, 2008, 10:03:58 PM »
I remeber that part, weighed about 30 lbs  ::)
I was working for Leslie Griffith Motors in 78, it was on F2 I had to do a cam cover change on (bike had fallen onto edge of curb and cracked right side, insurance was paying)
 Didn't some of them have a thick rubber buffer inside as well?
 It was to reduce noise as far as I can remember but I think they were really for German market (remember the proposed noise legislation in Germany?)
 BMW boxer couldn't meet db noise limits at 30mph with a dead engine
 Sometimes I'm amazed at the crap I remember (conditional learning  :D)
PJ
« Reply #9 on: December 25, 2008, 10:19:57 PM »
30 lbs... LMAO.. ;D
I got several laying in the shop, one where I see it all the time, and I always think, "Yup that off the latest most improved model...!!"
I think the lighter ones had a thin layer of grey rubber but not everywhere, much like point covers had.
Offline crazypj
  • I'm brill, me
« Reply #10 on: December 26, 2008, 06:32:16 AM »
Yep, you could see the brush marks in the grey 'paint' on most of the early ones.
 I think it was done for protection on the edges as much as anything else because I cleaned some off and there was only nickel on the curved bits
PJ
