Author Topic: The Grinding Lean transmission  (Read 6747 times)
Re: The Grinding Lean transmission
« Reply #25 on: January 10, 2009, 05:15:41 AM »
There is never room for a re-grind but a light polish might work. to be honest with all the used engines/cranks out there is it worth it?
Classic "Dirty Oil" pictures
That journal really doesn't look that bad to me BUT it is a pic. I agree a polish will more than likely do it. The problem I've run into with used cranks and rods is they have either been sitting in a non running engine for years and have they begun to rust or they been sitting out of an engine and are rusting.
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #26 on: January 10, 2009, 07:32:39 AM »
does anyone know a place to do a lighten, balance, and polish, for less than $199.00?
cycle exchange-$199
APE               -$225
your place      -????
« Reply #27 on: January 10, 2009, 07:52:56 AM »
cycle exchange-$199
APE               -$225
your place      -????
I've had APE do 6 cranks for me. 200.00 or 225.00 is dirt cheap. I would question the work if it was any less than that.
  • Like a well oiled
    • Undead Asphalt
« Reply #28 on: January 10, 2009, 08:27:22 AM »
alright, I'm just cheap I guess.
  • Like a well oiled
    • Undead Asphalt
« Reply #29 on: January 10, 2009, 09:57:53 AM »
the mains are  35.988mm  + or - .002mm
I think there's enough meat there to polish and reuse....  anyone?
« Reply #30 on: January 10, 2009, 10:07:54 AM »
measure the unworn part in the middle and the worn part beside it see if you can find any difference.
just polishing a crank should run 40 bux or less, its pretty quick, make sure they dont mark up the crank..
You should be able to tell if the rod small end is bushed or not, try a magnet, tho you should be able to see a collor fifference if it is bushed.
The rock could get in there if you were real sloppy at oilchange time.. come in ther on the plug or get pushed in if you wipe around the hole AFTER you pull the plug..
  • Like a well oiled
    • Undead Asphalt
« Reply #31 on: January 13, 2009, 11:55:41 AM »
the mains measure .001 or less difference on the unworn part as the worn part.
about the small end, theres no bushes, no trees, just wear.... lots of wear.
the engine must've had low oil levels for a while or something.
no matter, I wanna get new ones anyways.
« Reply #32 on: January 13, 2009, 08:51:01 PM »
Better be less than .001
