Author Topic: All of you with Bobbers - Let's see em'  (Read 106680 times)
Offline shaunzo
Re: All of you with Bobbers - Let's see em'
« Reply #25 on: February 12, 2009, 05:34:15 PM »
captain,
id like to think that it is a custom rear section; the entire rear section was chopped off and the swingarm was lengthened by six full inches.  of course i know what you mean...  once i get my shop cleaned up i will take a few pics and fill everyone in on my plans.
2007 kawasaki versys 650 - everyday
2008 xl1200n nightster - somedays
1981 cm400 bobber - somedays
1983 cm450 - nodays (gf's)
1982 kz1000j2 - a project
1976 cb750k - project bike
1971 norton commando 750
Offline shaunzo
« Reply #26 on: February 12, 2009, 05:35:10 PM »
i should menton that i do not own that bob, but i wish i did.
Offline Tim in Ohio
  • So I got that goin' for me, which is nice.
« Reply #27 on: February 12, 2009, 08:57:14 PM »
This is a great thread.  I really appreciate seeing progress pics.
So SPDIII please explain how you take it from here:
to here:
Is that a whole different frame?  or do you chop off some parts of the rear end of the bike and weld additional tubing to the orig frame to "hardtail" it?  I really want to try a project like this, but as you can tell, I need to aquire some know-how.  Thanks in advance,  ;)
1973 Honda CB350  Four
Check out my CB350F resto project...  watch a complete moron build a bike in front of your very eyes!: http://forums.sohc4.net/index.php?topic=38903.0
Offline spdiii
« Reply #28 on: February 13, 2009, 08:33:36 AM »
to here:
I chopped off some parts of the rear end of the bike and then welded additional tubing to the original frame to "hardtail" it. I see now that I should have taken more pictures, however it really was'nt that hard to do. The trick is to keep everything square. After I cut away the aft section of frame, I was able to line up the new sections squarely by leaving the swingarm bolted to the front part of the frame to use as as a guide. This worked out well because the swing arm pivots, allowing me to correctly align the new tubing. I also had to make a jig out of 2x4's to level the frame because it did not rest flat & level (by design). The original part of the frame is not symetrical , to allow easy removal of the engine from the right side, so the points where the new sections of  tubing are welded (bottom of frame) are different right & left. It actually took longer to sqaure everthing than it did to fabricate all of the parts and tack them into place.
Nick
'73 CB500
'73 CB500 Cafe
'74 CB550
'74 CB360 Bobber
'75 CL360
'76 CJ360 in progress
'99 Speed Triple
Bay City, MI
Offline Tim in Ohio
« Reply #29 on: February 14, 2009, 07:04:31 AM »
I chopped off some parts of the rear end of the bike and then welded additional tubing to the original frame to "hardtail" it...
Where did you get the tubing for the frame?  What type of steel is it?  I got a welder for Christmas and haven't even fired it up yet, so forgive the noob questions...  gotta learn sometime.  ;)
Offline Flying J
« Reply #30 on: February 14, 2009, 10:47:40 AM »
a few i found
Offline spdiii
« Reply #31 on: February 14, 2009, 03:17:29 PM »
[/quote]
 I got the steel from a local supplier,  ALRO I believe. I told them I wanted 1" tube for my project and they recommended a seemless eighth inch wall thickness. Seems a little heavy cuz the original frame is more like 1/16th but I was able to work with it & know it won't break ;)
Nick
'73 CB500
'73 CB500 Cafe
'74 CB550
'74 CB360 Bobber
'75 CL360
'99 Speed Triple
Bay City, MI
Offline Tim in Ohio
« Reply #32 on: February 14, 2009, 06:01:05 PM »
That bottom section of tube... does that have a bend in it? or is it two straight sections welded at an angle?  If bent... did the supplier bend it for you?  If you bent it... how?  I appreciate the knowledge sharing... thanks.
Offline Flying J
« Reply #33 on: February 14, 2009, 06:48:50 PM »
you can buy pre made bobber kits on ebay. Just have to weld them up.
Offline spdiii
« Reply #34 on: February 15, 2009, 04:34:12 AM »
[/quote]
 I bent them myself using a vise and a torch. It's nice having the tools to DIY.
Nick
'73 CB500
'73 CB500 Cafe
'74 CB550
'74 CB360 Bobber
'75 CL360
'99 Speed Triple
Bay City, MI
Offline fdbrat
« Reply #35 on: March 06, 2009, 09:29:16 PM »
1968 CL 450, weld on hard tail, Harley Tank, Sportster seat, 4 over fork tubes, etc..
Where did you get your weld oon hard tail. Im looking for one for my 550. If I had a shop id try fabbing one my self. But I dont have a shop.
Please inform me...
F.D.Brat
1975 CB750F
4-4, Dyna S and box
5 ohm coils / 5k ohm caps
In- .05 / Ex- .08
San Luis Obispo
Offline Pete T
« Reply #36 on: March 07, 2009, 01:26:12 AM »
just saw this on youtube,not mien,  its got to be one of the coolest honda bobbers ive seen, does anyone know where i can get a weld on hardtail kit for a 1970 cb350?
[youtube=425,350][/youtube]
« Last Edit: March 07, 2009, 01:28:23 AM by Pete T »
Offline pietenpol
« Reply #37 on: March 07, 2009, 04:44:35 AM »
This bike really was the first bobber I liked.
If you're not scared enough to wear a helmet, you're not riding hard enough.
Offline Pete T
« Reply #38 on: March 07, 2009, 12:47:26 PM »
ah man, i was actually looking for that picture, does anyone know anything about this build? like what year that yamaha is and what kind of hardtail hes got on there, if its a weld on kit or if he made it? man i would love to see the build thread for that bike
Offline pietenpol
« Reply #39 on: March 07, 2009, 05:29:13 PM »
I forget where I found the picture. But something I really like, and I'm not a big fan of bobbers. Glad you like it though.
BT650
« Reply #40 on: March 08, 2009, 08:37:14 AM »
Here's mine after reworking it some more with a smaller tank and fender and reworking the seat for the 4th time. Just trying to take it as far as possible without being able to weld a hardtail on.
Offline manjisann
« Reply #41 on: March 09, 2009, 08:18:46 AM »
BT650, even if it isn't a welded hard tail, I think it looks great. Someday I would like to build a nice bobber, just need to decide on a style I like, and BT yours comes close to the look I like. Definately food for thought.
Thanks for this great thread!
Brandon
1980 CB650 Custom
Offline greenjeans
  • 1972 CB750K2
« Reply #42 on: March 09, 2009, 10:45:33 AM »
pretty sure I saw that build over at caferacer.net    think his screen name is pampador ??
If I recall he was working on internal throttle and clutch as well.
somehow the link isn't working, but, the title of the thread is:  " xs650 project (not a cafe racer) "   so do a search in the build forum.
« Last Edit: March 09, 2009, 02:04:10 PM by greenjeans »
BT650
« Reply #43 on: March 09, 2009, 03:50:58 PM »
Thanks Manjisann! I know bobbers aren't as popular on this site, so I'm just glad to get any feedback at all. I like the cafe bikes too, just wanted to try something different.
Offline Pete T
« Reply #44 on: March 09, 2009, 04:33:45 PM »
thanks for the info, found the link: http://www.caferacer.net/forums/topic.asp?TOPIC_ID=7272 , that bike truly inspired me, im on a lookout for a xs650 for a summer project : )
750mikeb
« Reply #45 on: March 09, 2009, 06:41:08 PM »
Hi Here is my auto chop not a ton of rake but a nice amen saviour frame  most of it was given to me
750mikeb
« Reply #46 on: March 09, 2009, 06:44:11 PM »
1 more  this one shows the pinstripe a friend hand applied it was in real rough shape when I got it  mike
BT650
« Reply #47 on: March 10, 2009, 05:05:19 PM »
Nice ride Mike.
750mikeb
« Reply #48 on: March 10, 2009, 05:28:14 PM »
thanks I picked up a 75 750f Im working on the engine now I Will get to the rest later mike
Offline manjisann
« Reply #49 on: March 10, 2009, 07:50:06 PM »
BT, I want one of each  ;D I like the cafe look, but there is also something to be said about the bobber look as well. The important thing is if it looks how you want. I am seriously beginning to toy with the idea of bobbing my CB500, I think it could possibly cost less than cafeing it, but I've been known to be wrong when it comes to money  ::)  I may buy a little CL or a smaller 4 to cafe, just for the kicks of it all.
Thanks for all the inspiration!
Brandon
1980 CB650 Custom
