Author Topic: Clock Mount Ideas  (Read 2807 times)
Offline silver fox
Clock Mount Ideas
« on: January 24, 2009, 01:58:14 PM »
Decided to only mount my speedo on the front of my 400/4, but need some ideas and pics for a mount. I have also decided to get rid of the idiot lights and ignition from the front, so it will be pretty basic at the front. I have managed to get some small LED idiot lights, so will be looking at drilling holes into the speedo mount to fit them.
Anyone??????
Kind Regards
SF
  • Be careful you might get a
Re: Clock Mount Ideas
« Reply #1 on: January 24, 2009, 06:37:15 PM »
I'll try to take some pics of mine tomorrow and post them.
Offline silver fox
« Reply #2 on: January 25, 2009, 02:21:00 AM »
Many thanks, eagerly await to see it, i need some inspiration!
Regards
SF
« Reply #3 on: January 25, 2009, 09:55:55 AM »
So here it is albeit not very good. My camera kind of sucks and it the lighting in my garage doesn't help.
There is a metal bracket that bridges that area. This is actually temporary because I want to get some old school looking, but new mini gauges. I decided I want the tach. Next time I have it out of the garage I'll try to get a better pic.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #4 on: January 25, 2009, 10:09:02 AM »
I'm currently using only a tach too, but would like to have the critical speeds (30 MPH city & 60 MPH highway) covered. I thought I would redo the tach face with a nice white face and have the 30 MPH & 60 MPH on the tach as well. I’d calculate those two speeds based on 5th gear RPM speeds. Could also confirm real time RPM/MPH values with a GPS.
FJ
Offline silver fox
« Reply #5 on: January 25, 2009, 12:49:36 PM »
Thanks for the pic, would like the small gauges myself, but cant justify the cost at the moment, i have too many parts to sort. I also was thinking of using the original bracket, but might try and fab something up in ally, that looks nice. Although i might use that idea as a stop gap.
Many thanks
SF
Offline tsflstb
« Reply #6 on: January 26, 2009, 08:58:03 AM »
If you go with the stock tach, a bicycle speedo works fine and is pretty accurate up to 100mph.  It doesn't look very "vintage" though.
I found this one for $9.00.  You can then get rid of the stock speedo, drive cable and gearbox mechanism to save some weight also.
Offline silver fox
« Reply #7 on: January 26, 2009, 10:04:44 AM »
How have you got the tacho fastened into that position???? I can see you have re-shaped the top tree, it looks nice.
Any more info?? Pics???
Regards
SF
Offline tsflstb
« Reply #8 on: January 26, 2009, 01:06:25 PM »
I used the two holes in the bottom of the fork clamp, ran some bolts in and secured the tach with a hose clamp.
Offline silver fox
« Reply #9 on: January 27, 2009, 09:24:50 AM »
Like it, clever git!!!!!
When i get a minute i'll be looking at mine. My bikes at work, and we have a big inspection coming up, and no time to work on it >:(
Kind regards
SF
Offline uwjberg
« Reply #10 on: January 27, 2009, 02:40:46 PM »
tsflstb: that looks great - is that triple tree custom?
Offline tsflstb
« Reply #11 on: January 27, 2009, 08:27:17 PM »
It's just the stock triple with the bar mounts cut off and ground flat.
Offline crazypj
  • I'm brill, me
« Reply #12 on: January 28, 2009, 10:45:54 AM »
I bought a mini speedo for my XS800 and carved up the ignition switch mount. moving it lower meant I could'nt get to trip reset
PJ
