Author Topic: Looking for ways to pep up my bone stock 1975 CB550F Super Sport  (Read 2114 times)
FLEXXED
I purchased this bike around nine years ago and it is all original with 9403 miles one owner and am looking for the  ways to increase its horsepower and or responsiveness. Any suggestions would be most appreciated ....Daniel
Offline Lumbee
    • My pics...
Re: Looking for ways to pep up my bone stock 1975 CB550F Super Sport
« Reply #1 on: October 06, 2005, 01:02:58 PM »
...buy a 750  ;D
"I'm not a welder, but I play one on HondaChopper.com"
FLEXXED
« Reply #2 on: October 06, 2005, 01:32:27 PM »
...buy a 750  ;D
 sell me one for $300.00 and I will....but it has to be 1 owner with 9400 or less mileage...can you beat that deal?
MetalHead550
« Reply #3 on: October 06, 2005, 02:01:29 PM »
Loose weight! ;D
You could always do K&N, ect., pod filters and re-jet.  Dyna-S makes an electronic ignition kit to replace the points and condensers giving you better spark.  If you want low end you could try a different rear sprocket to change the gear ratio.  If by responsiveness you mean handling, some simple things you could do would be to get some modern, progressive rate rear shocks and put mabey 10 or 15W fork oil in the front tubes and get some high quality, sticky modern tires.  Modern disk breaks all around too.  If you want to spend alot you can have engine work done, like boring for more displacement and going higher compression and run 93 octane.  Mabey you could find a cam and have head work done.  All said these bikes were made long ago and its the character, looks, simplicity and reliability that most of us love and if I wanted more power Id buy a modern bike.  Like the ZRX 1000-1200 those things are cool!
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: October 06, 2005, 02:15:20 PM »
      The cheapest and easiest way to get a more "responsive" machine is to give it a proper tune-up i.e adjust valves, replace worn points/condensers, set dwell and engine timing, synch carbs, etc.. Amazing how this can "wake up" a bike.
       Other things to consider are replacing the steering bearings, swingarm bushings, and getting some new rear shocks. A better handling bike can increase the speed you ride at and the fun you have doing it.
       If just tuning it doesn't do it for ya then it's time to look in to bigger pistons. Or maybe just new rings. A thirty year old bike with just 9,000 will have a much cleaner exterior, but unless it's been ridden 10 miles each and every week for the last thirty years the engine could suffer from long periods of dormancy (This is just my opinion and is not backed by any scientific data at my disposal). A compression test with the engine hot should clear the matter up.
       As far as what's available "off the shelf" for performance increase for your bike, I'll have to defer to other 550 riders on the board. I bought a 750 :)
Yeah, like MetalHead550 just said (Damn, I type too slow)
jurob
« Reply #5 on: October 06, 2005, 03:57:48 PM »
all the bolt ons in the world will only make minimal difference in power and will more than likely be unfelt.
in my opinion. if your looking for power, get a different bike. i've had a few bikes in my time and my 74 750 is weak to me, but i didn't buy it for power. im sure in 74 this was powerful for its time.
Offline Chris Liston
« Reply #6 on: October 06, 2005, 04:17:07 PM »
My personal opinion and I ride with much larger cc bikes is that the 550 although under powered hangs in the twisties just fine and is pretty quick for what it is.  I'd not worry so much about increasing power but increase your comfort level on the bike and ride it like you stole it.  For more power, like others have said get a bigger bike.  The 50hp that the 550 is fine and you'll spend way to much boring it out for maybe 5-10hp more.
1976 CB550F Cafe in progress
« Reply #7 on: October 06, 2005, 06:51:09 PM »
The CB550 engine responds to the same hod rodder tricks that work with other 4 stroke engines.
You can up the bore with larger diameter pistons increasing displacment.
Domed pistons will up the CR.  You could go to 10.5 to 1 insteads of the current 9 to 1.  It should still only require pump gas, albeit higher octane.  But, this will make more power, too.
http://www.megacyclecams.com/
These people will make you a hotter cam for more breathing capability.
A freer flowing exhaust will also help breathing (more HP) at that end.
Almost anything you do above will require fiddling with the current carbs or adapting newer carbs with larger throats for added power increases.  Unless you have a dyno or lot & lots of time to play with the multiple adjustment inside the carbs, the carbs will be the most difficult to dial in to any modifications made to the engine for horspower.
I notice you didn't mention how much money you wanted to spend or the horsepower gains you are looking for...  Adapting a turbo would give you a hefty power increase!
I'm kinda with the why bother camp, though.  These bikes, when properly tuned, are quite a nice package as they are.  The handling characteristics are definately 70's.  And, more engine power will magnify all the limitations of that era, promting even more mods to the rest of the bike.  You'll impress people at the stoplight grand prix with engine mods alone.  But, a modern 600 class machine will be more than your match even with a couple (or more) thousand dollars in mods, especially on the twisty roads.
That doesn't mean you shouldn't do it if you want a wrenching and learning adventure that can be rewarding in its own right.  Just be careful what your benchmark for success is.  Otherwise, you may curse the day you touched it with a wrench.
But, if you are wimping out at the prospect of spending more than $300.  I suspect all you'll do is talk about it. ;D
Speed costs money.
Offline Killer Canary
  • Typical Bran Muffin
« Reply #8 on: October 06, 2005, 08:13:03 PM »
The simplest is to open up the intake and exhaust, which will gain you a small amount of performance but completely change the FEEL of the machine. If you do it yourself it won't cost a lot.
Kawi GPz900, H1
« Reply #9 on: October 07, 2005, 03:37:47 AM »
probably easiest is one of the 605 kits on ebay BUT you probably got $3-500 of machining to get done AFTER you pay for it!!
Offline Geeto67
  • A grumpy
« Reply #10 on: October 07, 2005, 04:00:00 AM »
if it is an all original bike, keep it all original and tuned up. stay on top of carbs and valves and you should be ok.
The only other thing I can suggest is to go find a SOHC cb650 motor and bolt it in the chassis (the mounts are the same).
Keep in mind this is a vintage bike it is not even supposed to keep up with the modern 500 and 550s out there.
Maintenance Matters Most
FLEXXED
« Reply #11 on: October 07, 2005, 05:46:03 AM »
Man that is awesome the amount of response people on here are willing to give..... I really appreciate all the help and suggestions I will definately be weighing out my options but will most likely just get a good tune up maybe electronic ignition and exhaust work and let my sweet girl stay stock as possible...that vintage look is what attracted me in the first place...... Thanks again everyone...Daniel
Offline Bodi
« Reply #12 on: October 07, 2005, 10:24:26 AM »
As an original it has a value premium. Modified bikes are usually worth less than stockers plus you've spent a wad of cash on the mods...
However, you have a few options. A hotter cam improves the engine a fair bit, the magacycle 130-00 cam improves the top end impressively and still lets the bike idle well. Megacycle and Yoshimura cams are less friendly and may need piston mods to clear the valves.
The Yoshimura 466 piston kit is an impressive change, you should put a new cam in with it; again the megacycle with high lift but not too much overlap is a good choice if you like a decent idle.
With these mods and the stock intake/exhaust the bike will still look dead stock and run a lot stronger. You should add an oil cooler with the overbore especially.
Putting a smaller engine sprocket on gives better acceleration with higher highway RPM, the engine doesn't mind spinning fast though and this is the easiest and cheapest improvement available.
An aftermarket exhaust with some carb rejetting halps a fair bit plus the stock exhaust can be mothballed and kept pristine for the day you decide to sell the bike.
