Author Topic: help with pics  (Read 1903 times)
Offline pinnacle
help with pics
« on: February 14, 2009, 01:05:42 PM »
so i am trying to post some pics and have them on photobucket when i try to post them it says file sixe exceeds the 256kb limit how do i reduce the size so i can post pics when i reply to some topics or want to show some progress i have made
1974 cb550, 1978 cb550, 1984 honda shadow vt750
Offline moham
  • .fnord.
Re: help with pics
« Reply #1 on: February 14, 2009, 02:17:22 PM »
Dude, you need some very basic application for viewing/editing your photos. Preview, iPhoto, Picture Viewer (I think) all have the ability to do this. Also, check the FAQ for a lot on this subject.
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline fastbroshi
  • Puppet
Re: help with pics
« Reply #2 on: February 14, 2009, 05:05:46 PM »
Try taking the pics in a lower resolution.  The quality may suffer, but you just have to hold still better.  Get a tripod.
Just call me Timmaaaaay!!!
Offline Spanner 1
Re: help with pics
« Reply #3 on: February 14, 2009, 05:16:44 PM »
Same prob. with pics., solved it by e-mailing to myself and resolution dropped enough to post on the site. Try that .
Re: help with pics
« Reply #4 on: February 14, 2009, 05:37:13 PM »
I'm using photobucket with no problem. You shouldn't be posting the photobucket link into the "additional options" area, but rather directly into your message. I don't think size is an issue that way.
I used to get the size error message using the "additional options" area, but never with photobucket "img.....img" address pasted into the message.
OCICBW
Offline pinnacle
Re: help with pics
« Reply #5 on: February 14, 2009, 05:40:49 PM »
i"ll try it then.
Re: help with pics
« Reply #6 on: February 14, 2009, 05:43:44 PM »
That looks...and sounds...nice!
Offline pinnacle
Re: help with pics
« Reply #7 on: February 14, 2009, 05:47:46 PM »
thanks mc it looks nicer now that i got the tank painted and removed the emblems and got my carbs fairly straightened out. i will take pics tommorrow and post thanks for the help chaps
Offline Bodi
Re: help with pics
« Reply #8 on: February 14, 2009, 07:25:28 PM »
I use a program called "GIMP" to mess with pictures. It's free! This does most of what Photoshop does - the stuff we generally need anyway (I don't have much use for YCM colorspace...).
To resize a phot in gimp, open it and on the window with the pisture select the "image" tab, and "scale image". The top set of numbers are the size, probably shown as pixels (change to pixels if it's inches or whatever). The chain image beside/betwenn the two numbers should be linked, click it to link if it shows as broken. Change the top number to maybe 640 (a standard picture size for landscape oriented images), when you hit "enter" the other number should change to something close to 480. In the bottom of the scaling window change the "quality" to "cubic (best)". Click "scale".
Now "file", "save as" the resized image - use "save as" or your original image will be overwritten. Click on "select file type by extension", choose "jpeg". Click "save" and you will probably see a window about exporting before converting to jpeg - either "flattening" (?) the image or going to RGB or greyscale, pick RGB for colour images or greyscale for B&W. Click "export" and you get a window to select jpeg compression quality, the file size gets bigger with higher percentage quality but the image looks pretty ratty below 50%, 85% is good - check the filesize after saving and resave with a lower percentage if still too high.
You can play with the image in a lot of ways, changing contrast and such too. I usually adjust the images using "tools", "color tools", "levels" to get a nice bright well contrasted image for posting. Messing with the "curves" just ruins the picture in my experience.
Offline Alan F.
Re: help with pics
« Reply #9 on: February 14, 2009, 07:30:21 PM »
I just use microsoft paint to reduce image size to 45-50% that usually gets them below the max file size, and every windows machine comes with paint.
