Author Topic: question about a new horn (update....put on relay)  (Read 3072 times)
Offline andy8190
Re: question about a new horn (update....put on relay)
« Reply #25 on: February 26, 2009, 12:56:42 PM »
ok so what should the reading at the terminl end of the headlight wires be?
Offline Patrick
« Reply #26 on: February 26, 2009, 01:46:43 PM »
On a perfect electrical system it would be the same as the reading at the battery. You probably are going to lose a few tenths, though.
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #27 on: February 26, 2009, 02:21:30 PM »
The headlight relay mod is just a band aid, used to side step and hide faulty wiring harness connectors and switches.  It only solves a small portion of the real problem
Well I disagree a bit with that, though I know you know far more than I do regarding m/c electrical systems ...
From what I understand it also lightens the load on your expensive and hard to find (for some models) switches. Also,running heavier gauge wire for the power to your headlights and or horn and relays allows you to pull more voltage for higher powered aftermarket items safely. Sure it is not a replacement for having a properly functioning wiring harness, but it helps in this instance even if you do.
