Author Topic: Jetting  (Read 2746 times)
Offline mrbreeze
  • Not your average
Jetting
« on: October 17, 2005, 11:18:03 PM »
Well......After more attempts than I would like to list right now, I finally have the combination!!!! I am back to my 137.5 mains but this is the first time I had them on with the needle in the 4th notch. Man this sucker is runnin now (and I haven't even synched it for the last two adjustments!)I guess I'm runnin a slightly fat main now but it just recently occured to me that my needle must be too fat.This bike has never in 5 years ran this good!!! I'm jazzed.... It's fun to ride again(now that its gettin in to the fall...Oh well...this spring will be good)
MEMBER # 257
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
Re: Jetting
« Reply #1 on: October 17, 2005, 11:29:34 PM »
what's yer bike?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline mrbreeze
  • Not your average
Re: Jetting
« Reply #2 on: October 17, 2005, 11:38:12 PM »
750 K5.4to1,pods,dyna ignition.
MEMBER # 257
Offline paulages
  • 1976 cb735
Re: Jetting
« Reply #3 on: October 18, 2005, 12:06:00 AM »
what were your stock mains for that model?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
eldar
Re: Jetting
« Reply #4 on: October 18, 2005, 07:43:04 AM »
Stock mains were usually 120s I think.
Offline dusterdude
Re: Jetting
« Reply #5 on: October 18, 2005, 07:53:58 AM »
oh jeez.we have a k8 guy thinking.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
eldar
Re: Jetting
« Reply #6 on: October 18, 2005, 08:22:50 AM »
Well them K8s require so little work and are so reliable that we usually do not have to think. But that is what happens when you have so few problems!
Offline mrbreeze
  • Not your average
Re: Jetting
« Reply #7 on: October 18, 2005, 11:05:29 PM »
My model came with 105's stock.The early 750's had 120's. Since I went 4 to 1 exhaust,pod filters, and Dyna ignition,I have worked with different combinations of 120,125,and 137.5 main jets And the middle 3 notches on the needles. "DUDES!!!!"........I am there finally and it feels good.Plan to synch this weekend and buy wings......take a flight!!!Will report back. PS....Hey Bob...Can I join the carburetor club now????
MEMBER # 257
eldar
Re: Jetting
« Reply #8 on: October 19, 2005, 07:33:50 AM »
You have an F model then huh. Those did have different mains than the Ks did.
Offline mrbreeze
  • Not your average
Re: Jetting
« Reply #9 on: October 20, 2005, 07:54:28 PM »
No Eldar.It's A K model.
MEMBER # 257
Offline dusterdude
Re: Jetting
« Reply #10 on: October 21, 2005, 05:25:06 AM »
yea eldar,the man said it was a k. ;D
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Re: Jetting
« Reply #11 on: October 21, 2005, 05:37:41 AM »
Hey Eldy, according to the factory manual, your K8 should be running #110 mains. Cheers, Terry. ;D
murtceps1
Re: Jetting
« Reply #12 on: October 21, 2005, 06:17:41 AM »
MrBreeze what problems did you have before. I am the owner ( not master) of a cb750k that is driving me nuts. I also run pod air cleaners I have been advised to decrease the size of my main jet but you have had success going the other way. Or did you compesate by altering the needle hight. My manual says main std jet 120.
My plugs are sooty
eldar
Re: Jetting
« Reply #13 on: October 21, 2005, 08:11:14 AM »
I think mine does have 110s and the F models are the only ones I know of that came with 105s now I suppose they could have been changed before and so it could be a K or it could be a K with F style carbs.
Offline mrbreeze
  • Not your average
Re: Jetting
« Reply #14 on: October 22, 2005, 09:13:40 AM »
I ran the 137.5 at the mid clip on the needle and it was okay at the top end but spotty in the middle.I moved the clip down to the 4th notch(which raises needle-- richer). Now it was noticably runnin rich so I tried going back to 120 mains.There,it was doing okay on the highway but lousy around town. Took carbs back off and moved clips to 2nd from top position(lowered needles--leaner).Now its great in the midrange but when you give er the onion,it bogs.From there ,went to 125 mains....better but still not on.Then I thought....I have already ran the 137.5's at mid clip and 4th notch... now that I'm at 2nd notch,lets try the 137.5's again. Bingo! Thats where mine runs best
MEMBER # 257
