Author Topic: carb leaks out the overflow on #4 carb only any ideas out there  (Read 1013 times)
Don Jones
I just bought a 1969 Honda CB750 KO and the #4 carb is constantly running gas out the bottom. It is driving me crazy. I can"t find parts for this thing either.thought oh it's a Honda parts everywhere and cheep but not for this thing. can anyone with experience in this bike put on the right course. please
Offline Gordon
  • 750K1, 550K2
Re: carb leaks out the overflow on #4 carb only any ideas out there
« Reply #1 on: March 26, 2009, 04:08:23 PM »
Tap the float bowl with the handle of a screwdriver.  Parts are plentiful and readily available.  Take a look in the FAQ for an ongoing list of suppliers.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #2 on: March 26, 2009, 04:10:56 PM »
Also, the overflow tubes crack. Happened on one of my KO carbs too. Some people put shrink wrap on em. I just soldered it.
No.
Offline BeSeeingYou
« Reply #3 on: March 26, 2009, 04:52:01 PM »
Sounds like a stuck needle valve, worn needle valve , or leaking float.  Easy to replace and parts are available from the many online sources.  Are the floats from the K0 copper?  If so they can develop hairline cracks or pinholes and allow gas to seep in and sink the float.  This happened on my XS650 and looking at the parts diagram they look like the same or similar floats.
« Last Edit: March 26, 2009, 05:02:47 PM by srust58 »
Offline tramp
« Reply #4 on: March 26, 2009, 05:11:59 PM »
run the bike
shut off the gas
just before the engine shuts down, turn on the gas
kinda flushes the system out
1974 750k
Offline 78 k550
« Reply #5 on: March 26, 2009, 08:40:00 PM »
I couldn't get 1 and 4 to stop leaking. I put new drain tubes on and it fixed my issue.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #6 on: March 27, 2009, 08:51:17 AM »
I had the same problem with the single carb on my '79 XT. Turned out to be a tiny bit of dried up fuel line schmutz trapped between the tip of the float needle and the seat. Cleaned it out, replaced the fuel line and everything was tip-top.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
