Author Topic: Fuel Cap Pin Removal  (Read 5634 times)
Offline Pwfyrcat1
  • What I'm doing when it's warm
« on: April 02, 2009, 08:22:16 AM »
I am prepping, trying to, my fuel tank for primer, but would like to remove the pins/fuel cap so that I can paint around the neck.  Can someone tell me how this done.  75, CB750.  thx
Just because you can, doesn't mean you should;)
2002 Yamaha Warrior, solo/souped/slammed/fast
2004 Yamaha V Star Silverado, 'The Sedan'
1992 Yamaha TDM 850
1975 Honda CB400F basket case that wants to be something
Offline Borkunit
Re: Fuel Cap Pin Removal
« Reply #1 on: April 02, 2009, 11:49:30 AM »
Pin punch it out.  I haven't re-assembled yet, but it looks like it won't be reusable.  I know someone on this site makes replacement kits, or you could just head down to the hardware store and look for a roll-pin of the appropriate length and diameter.
Offline jaknight
  • ....Round Town Ride......
« Reply #2 on: April 02, 2009, 12:15:58 PM »
Hi Guys,
I remember threads about this.  And, yes, HondaMan talked about a kit using a small screw and a special nut.  He had quite a few kits....... You might PM (email) him and find out if he still has them....... ;)
~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
Offline Magpie
« Reply #3 on: April 02, 2009, 01:09:46 PM »
Yes he does, I just ordered 2 sets for $6.40.
Cliff.
Offline markb
  • When I finish my current project I might be a
« Reply #4 on: April 02, 2009, 03:03:53 PM »
If you wanted to stay with the OEM look you can get the pins from Yamiya too but they're about $11 bucks plus shipping from Japan but its another option.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Johnie
« Reply #5 on: April 02, 2009, 04:21:45 PM »
Be careful if you use a punch as you could bend the bracket.  I put a small socket on the head end and small press pin on the crimped end.  I then use a C-clamp to push it through.  I also put some duck tape on the tank in that area to protect it.  I was able to reuse my pins.  I did not bother to remove the spring latch and the painter just masked that off.  To recrimp that pin back on I used a BB held on the C clamp with tape.
Yamiya has the 23mm, 25mm & 30mm pins.
« Last Edit: April 02, 2009, 05:51:55 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline mcuozzo
  • Bottle in front of me or frontal labotomy?
    • 77 CB750K - needs total rebuild
« Reply #6 on: April 02, 2009, 04:25:20 PM »
I drilled out the one side of the rivet, than used a small pick and hammered it out carefully.  I'll look for a replacement down the road (like a year...) when I'm getting the bike back together.  Probably just get the Hondaman kit!!!
Offline Johnny5
    • CB350F build thread
« Reply #7 on: April 02, 2009, 05:08:23 PM »
I had good luck using a small nail as a punch. That way I dont bend the tabs on the tank.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Pwfyrcat1
« Reply #8 on: April 04, 2009, 10:22:40 AM »
The pin holding the spring, came out fine.  Smacked the other side good a couple of times before I realized i was bending the tab.  Oh yeah, I'm gonna get that sucker out of there!!!
1992 Yamaha TDM 850
Offline Johnie
« Reply #9 on: April 04, 2009, 11:25:15 AM »
Use the press method described above...you will not damage that bracket...
Oshkosh, WI  USA
Offline Pwfyrcat1
« Reply #10 on: April 04, 2009, 03:59:19 PM »
got it...Dremels are your friend.  I ground away the left side of the pin, and with hammer and small nail, pushed it out the other side. success ;D ;D ;D ;D ;D
1992 Yamaha TDM 850
Offline morethrottle
« Reply #11 on: July 16, 2010, 03:46:50 PM »
Thank you to Johnie! That worked beautifully!
2005 Yamaha YZ250F (stolen)
1974 Honda CB750K4(836)
1971 Honda CB500
1971 Honda CB450
1976 Yamaha XT500C
Offline Johnie
« Reply #12 on: July 16, 2010, 07:03:10 PM »
Glad it worked out for you. And welcome to the board!!!
Oshkosh, WI  USA
