The SOHC/4 Patch & Pin Set is available at the SOHC/4 Store.
I have intake boots for 750A (all years) and 550F airbox boots ready to ship. I'll have 550K airbox boots and 750K intake boots in about a week. I should have 78 750F intake boots soon. ..........Paul
Quote from: 05c50 on April 05, 2010, 06:49:28 PMI have intake boots for 750A (all years) and 550F airbox boots ready to ship. I'll have 550K airbox boots and 750K intake boots in about a week. I should have 78 750F intake boots soon. ..........Paulso are the 750A boots the same as the 77-78 K boots??
I did what Hondaman did. Rounded up all the boots (8 sets). Next I poured my 4 oz of Wintergreen into the can and placed 2 sets of boots into it. Next I poured Xylene to cover them. Left till soft. Repeat with same mix. A couple of the boots swelled, but returned to normal size in a couple of days. Worked like a charm. I bagged them in sets of 4, tossed them in the carburator box and done. Near as I can tell there is no magical mix ratio.
I tried Wintergreen and water mix to soften 6 sets of 550 and 650 carb boots. The water method was offered as an alternative to xylene (which you should not heat). I used 8 ounces of Wintergreen (bought a local pharmacy) mixed with about a gallon of water (boots completely submerged) and heated the whole deal on the barbecue to the point where little bubbles were forming on the boots. Kept it at that temp for about 1 hr stirring off and on to keep the wintergreen oil mixing with the water and not settling out. This process worked really well. The boots were initially rock hard and basically unusable. Now all the boots are quite soft and flexible. They are at least as flexible as NOS boots. I had no issues with swelling but the smell of wintergreen does persist for awhile. I did these boots 3 weeks ago and there has been no change in their flexibility, still soft, pliable and fully usable. The smell is diminishing and isn't bothersome. You should do this process outside though as the odor would linger for weeks indoors, maybe longer! I was skeptical of this process at first but am now a total convert. Highly recommend if you want your carbs to seal properly and be easy to install and remove.
Hi, everyone.This is Pavel from NY.I recently got my first bike(a small project) 1978 cb750k (k8)And lo and behold... I learn about the imposibility to get the 2 and 4 carb insulators(boots).So, not giving up I ordered two new sets of 1 and 3.Took the old cracked, broken rocks of carb boots off and put the correct new ones in.Then the fun began - the 2 and 4, although exact mirror images of 3 and 1, are not interchabgable - due to the vertical incline of the intake openings (so they are tilted both horizontally to reach the wider carbs; and vertically for no apparent reason other then improved mixture flow).When flipped around the engine side of the boot points up and to the right.... ughAnywho, I didnt give up then either - I flipped all four boots ever so slightly to come closest possible to a flat and even fit with the carbs. Put everything together and there was improvement, but no way of telling wether I got sufficient sealing.Can you guys recommend a way to tell if I am losing vacuum at the boots before I look into carb tuning?Oh, and of course, I am looking for new boots 16112-405-000 and 16114-405-000 or home made versions. I'll take pics when I take carbs off again to show what I am on about for others in my shoes.
Quote from: bubbafun101 on April 07, 2010, 05:46:11 PMI did what Hondaman did. Rounded up all the boots (8 sets). Next I poured my 4 oz of Wintergreen into the can and placed 2 sets of boots into it. Next I poured Xylene to cover them. Left till soft. Repeat with same mix. A couple of the boots swelled, but returned to normal size in a couple of days. Worked like a charm. I bagged them in sets of 4, tossed them in the carburator box and done. Near as I can tell there is no magical mix ratio.The wintergreen oil is expensive and irrelevant.The process will work the same with xylene only, and be a lot cheaper too.I was shocked that a tiny bottle of wintergreen would cost so much - so I proceeded without it, got great results........
Quote from: tbpmusic on April 10, 2010, 08:34:28 PMQuote from: bubbafun101 on April 07, 2010, 05:46:11 PMI did what Hondaman did. Rounded up all the boots (8 sets). Next I poured my 4 oz of Wintergreen into the can and placed 2 sets of boots into it. Next I poured Xylene to cover them. Left till soft. Repeat with same mix. A couple of the boots swelled, but returned to normal size in a couple of days. Worked like a charm. I bagged them in sets of 4, tossed them in the carburator box and done. Near as I can tell there is no magical mix ratio.The wintergreen oil is expensive and irrelevant.The process will work the same with xylene only, and be a lot cheaper too.I was shocked that a tiny bottle of wintergreen would cost so much - so I proceeded without it, got great results........That's all I've ever done with them too.Xylene and a shot of Tranny fluid in a large glass jar.They turned from bricks into pliable boots after 4/5 days soaking.They'll still be fine to use.
K and F models carb insulators Z1 Enterprise set of four carb insulators for CB750 K and F models: $76.21 Honda Parts Direct $76.88 for set of 4 insulators A and B $40.98 CB750 A model sets for Grumberg from Honda Parts Direct if they are still available.I have been using my Wintergreen and xylene mixture for 2 years on 4 bikes and all are running and idling fine with no vacuum or air leaks. $10 worth of ingredients saved me over $300. Why throw something away if you can make it work again?
