Author Topic: And the lesson here is........  (Read 4051 times)
Offline gerhed
« on: April 10, 2009, 01:42:04 PM »
Don't stuff those blue paper shop rags into your carbs to choke them
because some of the paper may tear off and get stuck in your
throttle slide and hold it Wide Open when you start the bike for the first time
in 4 months.
--kill switch may have saved the day--not sure yet
<a href="http://i170.photobucket.com/albums/u251/gearheaded_photos/ThumpWide.swf" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://i170.photobucket.com/albums/u251/gearheaded_photos/ThumpWide.swf</a>
          83 XL600R in CB360 Frame
Offline Ecosse
  • Member #4139
    • My 550 walk around video
Re: And the lesson here is........
« Reply #1 on: April 10, 2009, 03:48:52 PM »
man, i hope all is well gerhed! more info on the set of wheels please.
1974 CB550K
                                  Your 1%er name
Offline gerhed
« Reply #2 on: April 11, 2009, 02:12:33 PM »
That machine has a Honda XL600 motor (single, 4 valves, dual carb, dual exhaust, magnesium cases, 50 horses)
that I stuffed in a CB360 frame.
Started it up later seemed O.K.--still backfiring though.
CDI ignition--not much to do there--hopefully it's just rich.
Offline Ecosse
  • Member #4139
« Reply #3 on: April 11, 2009, 02:36:37 PM »
Hmmm, Ill have to look into this XL600 you speak of.
Thumpers have that special something. :)
1974 CB550K
                                  Your 1%er name
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #4 on: April 11, 2009, 06:20:50 PM »
Don't worry about the back firing, that's from cycling the kill switch while running. My four wheeler does it too.
That reminds me of something that happened to me a year ago...or so.
I was out riding through the woods on my Husky 400 enduro.....and the top of the round slide mikuni vibrated off.
I never thought the engine was capable of such high rpm's.... :o
 Matt.
Gallery at:
Offline Ecosse
  • Member #4139
« Reply #5 on: April 11, 2009, 11:17:12 PM »
gerhed, when one cylinder isn't enough.  ;D
part one
part two
1974 CB550K
                                  Your 1%er name
Offline gerhed
« Reply #6 on: April 12, 2009, 04:00:15 AM »
part one
part two
Wow !
I've been scooped !
Offline Geeto67
  • A grumpy
« Reply #7 on: April 12, 2009, 04:04:46 AM »
I think the real lesson here should be "Don't post a video that you can't pause or adjust the sound on".
Maintenance Matters Most
« Reply #8 on: April 12, 2009, 04:38:42 AM »
Just "right click" on the video and click "play" and it will stop..
Offline Ecosse
  • Member #4139
« Reply #9 on: April 12, 2009, 05:06:48 AM »
part one
part two
Wow !
I've been scooped !
FWIW: I'd take your 'hybrid' any time. If you have some picture of it I'd love to see.
1974 CB550K
                                  Your 1%er name
Offline gerhed
« Reply #10 on: April 13, 2009, 07:27:49 AM »
part one
part two
Wow !
I've been scooped !
The thumper engine in the video used to be in this frame.
Offline Ecosse
  • Member #4139
« Reply #11 on: April 28, 2009, 11:44:19 PM »
just wondering why you chose a cb360 frame? is it just what you had or is it a matter of fit? do you think this moto mill would fit in something small such as a cb450 frame? i'm very intrigued by this engine and am thinking about frame options; i also wonder if it's (the 600 or 500) related to the gb500. had a chance to buy one new in 1988 and passed it over. what a boob i am.
sorry for picking your brain about this again. what's the latest with your thumper? is the motor ok?
1974 CB550K
                                  Your 1%er name
Offline gerhed
« Reply #12 on: April 30, 2009, 03:25:29 PM »
Ecos,
I had the 360 frame plus a title that goes with it.
The 360 engine went into an earlier 3-wheeler.
The engine is a little tall for the frame but I'm sure it weighs less than the original 360 motor.
I think the '83 version that I have was that only one with 2 carbs.
It is essentially the same engine that's in the GB500.
Mine is 589 cc's.
The engine is dry sump so you'll need to add an oil tank to whatever frame you choose.
I also replaced the rear swing arm with a longer one
inorder to move wheel back and give room for the oil tank.
A heavier frame might be be a good idea since I can feel flex
in the 360 frame when the hammer is dropped.
The engine does seem to be O.K. --after it's brush with death.!
Phil
Offline Ecosse
  • Member #4139
« Reply #13 on: April 30, 2009, 03:40:53 PM »
brush with death.  ;D
another thought was to follow the lead of others; some are converting their xl600 to street tracker. but i think one could wrangle out a cafe bike too. i'll post one man's blog on his (impressive) transformation in the other bikes category. i like the kick start over the later model's electric only.
a little flex when the hammer is dropped? that must be entertaining! what swing arm did you use? i get the impression that some sohc arms interchange.
anyway, thanks for sharing.
~Bill
1974 CB550K
                                  Your 1%er name
