SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
Proven Tricks & Tips / How To's - NOT for Quesions
Brakes
(Moderator:
Gordon
Topic:
Stainless brake lines - CB350F
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Stainless brake lines - CB350F (Read 5039 times)
Sparked
Hot Shot
Cheaper then therapy
on:
April 27, 2009, 08:52:04 PM »
I was looking on bikebandit.com for replacement stainless brakelines for the front brake. What is the difference between the cheaper MSR lines vs. say the goodyear? Also, how do I choose the proper lengths of brake line, is there any way to cross-reference the part numbers to honda's?
Logged
1972 CB350F
1982 CM450A
1961 Ford Falcon (time for four wheels)
themotoworks
addict
Enthusiast
Re: Stainless brake lines - CB350F
Reply #1 on:
April 28, 2009, 05:04:00 AM »
check out this guy, pampadori @ caferacer.net, he's got a thread under member products and makes these lines custom, if you need a specific length he can do them for you, I got mine and it's great
Logged
www.roccitycafe.com
<- my sideline turned living
BobbyR
Really Old Timer ...
Proud Owner of the Babe Thread & Dirty Old Man
Reply #2 on:
April 28, 2009, 02:56:49 PM »
I went stainless and they are very good. I would suggest you rebuild your master cylinder or at least clean out any gunk in there. This way you will get the full benefit.
Logged
OldSkool
Full Member
Reply #3 on:
April 28, 2009, 05:11:00 PM »
Also make sure to check out Z1Enterprises.com they have an assortment of Goodridge brake lines and fittings, I was able to outfit my 550 with braided SS lines for the front for about $75 using the existing banjo bolts. Plus they are super helpful over there if you call with questions and shipping is super fast!
Good luck
Logged
Sparked
Hot Shot
Reply #4 on:
May 07, 2009, 07:17:28 PM »
Ok, I got the stainless line sorted out. The industrial place I was going to try couldn't help me because they had nothing in stock that could stand up to the brake fluid. But a hotrod speed shop in town set me up with banjo bolts, prefabed line (Ernie's) and lower JIC to -3 flared fitting. The tricky part I was running into was there aren't JIC to metric fittings available that I could find. I'm going to fix that issue by bending myself a new lower brake tube with a imperial fitting on one end to mate to the stainless line and a metric on the other for the brake caliper. All said and done cost me $114 CDN.
Logged
1972 CB350F
1982 CM450A
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Brakes
(Moderator:
Gordon
Topic:
