Author Topic: How to make your CB750 stop like a modern bike....  (Read 51414 times)
Re: How to make your CB750 stop like a modern bike....
« Reply #50 on: January 22, 2016, 06:05:56 PM »
As i said, Frank did spacers to align calipers with rotors.
Bert
Envoyé de mon SM-G530W en utilisant Tapatalk
No, I mean on the discs..?  were the discs spaced out from the hub..?
Offline bert96
  • past ride
« Reply #51 on: January 23, 2016, 01:49:41 AM »
Yes I put spacers behind the disc.
Hub-spacer-disc
Bert
Envoyé de mon SM-T530NU en utilisant Tapatalk
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
« Reply #52 on: May 19, 2016, 11:29:19 AM »
I have no space left to displace the additional disc. The tacho cable is close the disc with  rivets as it is routed outside its guide.
A friend made spacers to use under the caliper bracket making it parallel with the disc. One spacer much easier than 4 std washers i used before. 3 washers 1.5mm thick + 1 thinner = total 5.3mm  a little bit too much. 3 washers of 4.5mm was to little.
Spacers are 5.0 mm thick. 2 for upper M6 bolts, OD 14.5mm, ID 6.5mm. For lower M8 bolt: OD 17.5mm, ID 8.5mm. I preferred to have the inner diam a little bit extra  (0.5mm)for easy assembly
This will make life easier when changing tire and the  right caliper must be removed completely with bracket to be av´ble to remove the wheel. Fiidling with the washers, no thanks!
« Last Edit: May 19, 2016, 11:31:44 AM by PeWe »
Offline Mantree
« Reply #53 on: August 04, 2016, 06:49:38 PM »
Even my dohc cb650 had the squeal I have owend 4 old CBs and all of them had it
Offline Godffery
  • Godffery's Garage
